Posted by choochoo_baloo on 25/10/2021 02:16:43:
All of this, is to ask: is the generic HSS to blame (cheap bundle from RDG) ie should I upgrade to a better quality HSS blank? Admittedly I'd assumed that on hobby machines at least, HSS was much of a muchness.
The HSS might be to blame, but there's a long, long list of other possibilities. Rather than jump to conclusions about 'quality', I prefer to isolate causes methodically.
When things go wrong, it could be due to the Tool, Material or Operator. Perhaps all three.
Operators are major suspects. Beginners often have hazy ideas about tools and materials, and are quite likely to leap into the deep end by tackling jobs an expert would approach cautiously. They might believe a clapped-out second-hand lathe is in perfect working order or have stripped and re-assembled a good one incorrectly. Might have fitted a QCTP before confirming the lathe cuts OK with a plain tool-post, and not realised the QCTP is wonky. Possibly, the HSS got too hot during grinding and was cracked by cooling too abruptly in water.
Not all materials machine well. Some are easy, others all but impossible. It pays the beginner to start with straightforward materials, and tackle awkward customers later. Silver-steel is a little difficult.
Tool problems are another complication. Choochoo's HSS is only one part of the system. If everything else about the lathe set-up is OK, and the HSS fails again, then maybe the HSS is unsuitable. Or perhaps not: often assumed there are two sorts of HSS, 'quality' and 'rubbish'. Actually there are seven different types of HSS, and not understanding which is which opens the door to trouble. Though ordinary M2 cuts metal OK for me, it's not as suitable for lathe tooling as M42. Possibly Choochoo's HSS is for wood-working… )
Be nice if all my workshop problems were due to poor quality tools and materials. It's not true. Starting out as a self-taught learner I had failures galore, but get much better results today. No magic or special gear – the big difference is I've learned a lot! (And still have a long way to go.)
If I was Choochoo, I'd start by practising on leaded Mild-steel with the HSS tools mounted in a conventional tool-post. If there's trouble, check the lathe for untoward movements.
Having made sure the lathe is OK, grind several more HSS tools. Be careful not to overheat the tip – if HSS goes blue, that section is ruined and has to be ground off to get to a undamaged bit. Plunge cooling over hot HSS is likely to crack it.
If the suspect HSS cuts leaded mild-steel OK from the ordinary tool-post, try the Silver Steel. If silver-steel cuts OK switch to the QCTP and confirm that's good too. It will be necessary to experiment with feed-rate, RPM, and depth-of-cut for best results. Dump the HSS only when confident it's been nailed as the cause – guilty beyond reasonable doubt. The investigation has extra value if it flushes out other problems. Persist, and all will be well.
