i need to drill a number of small holes into cz120 engraving brass, the holes are 1mm and 2mm diameter and the stock thickness is 3mm thick, the holes are all through, the problem is that my drill bits keep breaking, I'm drilling on a cnc mill, can anyone suggests feeds and plunge rate speeds etc, it's been suggested that I use a parabolic drill would this be a good idea, any suggestions welcome
