Posted by Michael Gilligan on 06/11/2021 21:05:50:
So which bit of running and testing results in a machine being delivered with change-wheels that don’t fit ?
This all started out as a simple enquiry about feed speeds & now I feel that I am being put on trial.
First the machine came with all the wheels in the tin box. It was a long time ago & I am sure of that & I think that the bushes were in a couple of the wheels. If I remember rightly, the adjustable spindles, that slide up & down,were not fitted- . But my memory has faded over 9 years so I may be wrong. I do know that I had to make some spacers for when there is a situation where one does not need a gear wheel so as to fill the void. I also know that the retaining washer still jumps out of the spindle because it does not necessarily sit vertically if the square end of the spindle finishes at an angle when tightened. That lets the gear wheel come off.
But while we are at it – some explanation, before I get slung in jail
I bought the machine through my business before I closed down to make use of the VAT & depretiation tax advantages etc. I intended to keep it for my own use after I retired. So I bought it before I needed it. But I did not use it for a long while as I went sailing for a couple of years when I did sell up. So it was out of warranty & i did not want the hassle of uninstalling a lathe that I had built up onto catnic lintols ( So its working height is 9 inches higher than the norm) & would need lifting down etc.
When I did get to use it, the on off switch often had to be pressed lots of times before the lathe would start- Up to 6 presses of the on/off button- If I pressed the green button & nothing happened & did not press stop, it sometimes engaged a little while later & started running, without warning- With my hand in the b…dy thing.
My solution was to remove the back cover place a bit of wood against an electrical part that seems to engage on a rail of some sort. Then refit the cover, forcing the wood against the part & forcing it onto the rail. Now it works first go 95% of the time & if not, I invariably get it to go second push. In any event I have learned the hard way to make sure I turn it off if it does not start.
As for machining I purchased the QCTP. I do use this for boring, but only that. It is not much use for anything heavy due to deflection. I donot use the topslide because when parting off one can see it dip up to 6mm if the tool catches.-Yes I know about gib strips- I have had to remove the topslide & mount the 4 way tool post on a block on the cross slide so as to get rigidity. At least I can now part off easily with an eclipse blade. This is really what prompted me to look at powering the feed again so I can get a nice even cut when parting off. But one should be able to mount the tool holder on the topslide & still part off OK
So as far as I am concerned there could not have been much quality control. But I had the machine to long before I actually used it to complain to Warco
I do not have a lot of faith in the WM16 mill either. But that is another subject.
Edited By Sam Longley 1 on 06/11/2021 22:32:28
