Faulty Materials
Faulty Materials
Home Forums The Tea Room Faulty Materials
Viewing 25 posts - 1 through 25 (of 41 total)
  • #770999
    Phil P
      @philp
      I have just taken delivery of four different sizes of flat steel strip from a well known supplier based in Milton Keynes.
      One of them is 1/16 x 1/4 and “very” badly rusted all over on one side and will not clean up as it is pitted on the surface. All have some degree of rust on them.
      Two of the imperial 1/16 and 1/8 thickness strips are not flat strip material but have been sheared from 1.5mm and 3mm sheet material so are well undersize on the thickness, they are also twisted and bent from being sheared.
      I have contacted the vendor to express my dismay, and he responded by saying I should “feel jolly lucky” as the 1/16 x 1/4 is actually obsolete.
      As for the distorted strips he told me to put them in a vice and get the twist out myself.
      As for the rust he told me to use a scouring pad and then coat it with oil.
      Does anyone else think I have been sent useless scrap or is it just me ?
      Robert Atkinson 2
        @robertatkinson2
        I think you have been mis-sold at least.
        If they adverised imperial sizes and you ordered imperial sizes then they should not subsitute metric without your agreement. Again strip is not sheared off sheet.
        If it is the obvious supplier then their terms and coditions are very suspect. For example:
        “Descriptive matter illustrations, dimensions and weights issued by the company are for guidance only and are not binding. The company reserves the right to alter patterns and designs without prior notice”
        Clearly breaches weights and measures legislation. Mind you that also says you must sell in metric  measurements so 1/4″ should be sold as 6.35mm (1/4″).
        I’d be talking to Milton Keynes Trading Standards….
        Robert.
        #771011
        Andrew Tinsley
          @andrewtinsley63637
          The well known supplier in Milton Keynes, is well known for selling sub standard metals. He also could not care less about the comments of his customers.
          Solution is DO NOT trade with this dreadful person. I believe that others on this forum have also been landed with rubbish when dealing with this individual.
          Andrew.
          #771018
          Oldiron
            @oldiron
            If you paid by credit card ask them for a refund. Trading standards should look at them. Publish the name here so others do not get caught out as well.
            #771056
            Phil P
              @philp
              Looks like rust is a recurring theme if their Facebook photo’s are anything to go by. !!
              I wish I had seen these before I ordered from them, it looks to be a right old dump of a place.
              462598642_8464191043662472_9149162023078994002_n
              462732528_8464190673662509_1036858738262641829_n
              462590419_8464190670329176_4018286578446982365_n
              462487308_8464190646995845_5557018493215308666_n
              #771057
              Clive Brown 1
                @clivebrown1
                For on-line and distance purchases you have the legal right, within two weeks, of a return for a full refund. A fault does not need to be claimed, although you might not get back the return postage and this seller doesn’t sound too cooperative. Credit card Section 75 protection only applies over £100.
                #771087
                  The Terms & Conditions make interesting reading:
                  https://www.mkmetals.co.uk/terms-conditions/
                  The word ‘bargepole’ came to mind.
                  Edit: __ from the public record [make of it what you will]
                  https://find-and-update.company-information.service.gov.uk/company/01401716/filing-history
                  #771088
                  Frank Gorse
                    @frankgorse
                    Fawlty Materials?
                    #771094
                    gerry madden
                      @gerrymadden53711
                      I am not surprised by the OP’s experiences. I went there once !
                      Gerry
                      #771100
                        ManKy Metals😮
                        #771107
                        Dave Halford
                          @davehalford22513
                          Never buy from a farm and read all the reviews all the good ones are local
                          #771190
                          old mart
                            @oldmart
                            I have been lucky with buying bits of metal on ebay, the feedback scores help a lot.
                            #771205
                            duncan webster 1
                              @duncanwebster1
                              As you bought it mail order you have an absolute right to send it back for refund, even if its not faulty (which this plainly is) . If you bought it with PayPal they are very good at refunding, otherwise contact your credit card provider. Never pay for anything like this by bank transfer, much more difficult to get a refund
                              #771239
                              Martyn Cozens
                                @martyncozens74564
                                I purchased some tin plate for boiler cladding for a loco I’m building from the same company in Milton Keynes. The packaging was pathetic (tin plate was sandwiched between two pieces of corogated cardboard nothing to give it any ridgidity) so by the time parcel force had chucked it around in their depots half of the sheet was creased and un-useable. Contacted the company sent photos they said it was parcel Forces problem, I certainly woundn’t use them again.
                                #771260
                                Mike Hurley
                                  @mikehurley60381
                                  I was similarly ‘stitched up’ by this company a few years back and have never used them again.
                                  The lesson here Phil is to always do a search on the forum here before sending money to a company you have not dealt with before!
                                  #771269
                                  Jim Nic
                                    @jimnic
                                    Living fairly close to this company’s premises, I bought my first metal stock from him when I started modelling around 14 years ago.  I was not impressed either with the premises, the proprieter or the metal and have not been back.  Frankly I’m amazed he is still trading.
                                    Jim
                                    #771336
                                      Duffers guide to buying metal:
                                      1. Random scrap.   Advantage, cheap! Disadvantages.  Pot luck what the metal is, and may not be machinable.  Many scrapyards are downright unfriendly; my local yards buy metal but don’t sell it.
                                      2. Selected machinable scrap from a known source.   Advantage, cheap!  Disadvantage.  Location dependent.  None available where I live, and, because metal is costly, many firms these days have an exclusive deal with a recycler.  Worth asking if opportunity presents, but don’t be offended by dusty answers.
                                      3. Off-cuts sold by a small business, perhaps online.   Advantage,  moderately cheap and they post it.  Disadvantage.   Material and storage condition vary wildly.  Buying is always a bit risky, and as we see in this topic, there are examples of bad practice!
                                      4. DIY Stores.  Advantages: available, and can be selected.  Disadvantages: Very limited range. Costly and not particularly machinable, some horrible.  No specifications.
                                      5. Metal sold by a local metal stockist.   Advantages: can be bought to specification, and the metal will be something like it!  Prices moderate, cheaper if you buy by the ton!  Usually properly stored.  No carriage charges.    Disadvantage:  buying small quantities makes it more likely rolling-mill ends or off-cuts will be supplied.  May not be keen to deal with hobbyists, who are often ‘difficult’ and only spend tiny money.
                                      6. Metal sold by an online metal stockist.   Advantages: can be bought to specification.     Usually properly stored.  Often willing to supply small quantities.  Delivery.    Disadvantage: Prices higher, plus carriage charges. Buying small quantities makes it more likely rolling-mill ends or manky off-cuts will be supplied.
                                      7. Professional supplier who issues certificates.   Advantages: metal can be bought to specification, and will be correct.  Disadvantages.  Cost, Minimum Order Quantities apply, and this class of supplier rarely wants to deal with private individuals.
                                      8. Specialist Hobby Supplier.  Advantages: sell the difficult to find metals and stock sizes needed by hobbyists.   Mostly good to deal with because they value their reputation and know all about us!   Disadvantage: cost.
                                      As always, chasing bargains increases the risk…
                                      Tony Pratt 1
                                        @tonypratt1
                                        Jim
                                        Exactly my experience, used once never again!
                                        Tony
                                        #771350
                                        Clive Brown 1
                                          @clivebrown1
                                          Their Face-Book entry describes the business as a scrap merchants, “nuff sed” as LBSC might have put it.
                                          #774094
                                          Phil P
                                            @philp
                                            Well I had a bit of a result yesterday.
                                            I originally bought the metal using Paypal, so I put a claim in through them for “Goods not as described”
                                            They have fully refunded me including postage, and I do not have to send the rusty metal back.
                                            Phil
                                            #774103
                                            Nigel Graham 2
                                              @nigelgraham2
                                              It looks as if this character is a scrap-dealer who has spotted a potentially more lucrative market for factory-clearance metal, but has no idea how to look after it, or more likely, just does not care.
                                              It’s not the material that is faulty, but the dealer, who “stores” the stuff so badly he spoils it.
                                              Selling sheared material as “strip” suggests he does not really understand materials and metalworking, too, except as something he can sell.
                                              Dave – Point 5. Off-cuts and rolling-mill ends may be all the buyer needs as long as he can extract what he wants from it. It is not a reflection of the metal’s grade and quality.
                                              However, your more general point about many companies’ unwillingness to sell to private individuals does often mean our only choice is the hobby’s own suppliers. They presumably buy in trade quantities, as a factory would, but we pay not only a pro-rate share of the retail metal cost but also for cutting, packaging and carriage.
                                              When I operated a factory materials-store I noticed that the steel stockholder MacReadys’ Ts-&-Cs specifically said it will not sell to private customers. I don’t know how common that is, but some firms might simply refuse us even if not in a formal load of legalese.
                                              #774122
                                              Ches Green UK
                                                @chesgreenuk
                                                Good list Dave, thanks.
                                                How does one find out who these suppliers are? Are they the companies that advertise on Model Engineer plus some others? Or is it a moving target eg a new CEO takes over so standards drop/rise, or a buyout changes the quality.
                                                The only way I can see how to construct such a list is through a combination of personal experience by trying all suppliers, reading forums and word-of-mouth. That could take a long time, and is maybe another barrier to entering the hobby.
                                                Ches
                                                #774164
                                                  Phil
                                                  What a very happy ending to a miserable tale
                                                  … spend your refund wisely and tell us where
                                                  Robert Atkinson 2
                                                    @robertatkinson2
                                                    Nigel,
                                                    The “not sell to private individuals” clause is becoming all too common.
                                                    There seem to be 3 main reasons, somtimes a combination:
                                                    1/ Can’t be bothered with small orders and potentially needy customers. (Professional customers can be just as bad).
                                                    2/ Semi-legal. Don’t want the effort and liabaility of dealing under the various consumer protection legislation like warranty and right of return.
                                                    3/ Legal. The products they sell do not meet consumer standards e.g. safety, marking, instructions and are intended for industrial / professional use. In some case it may be illegal to sell a product to the general public e.g. EPP regulations.
                                                    In my associated hobby of electronics and test equipment a major company, Keysight (formerly Agilen originally Hewlett Packard) has started to enforcedthis and is refusing sales or support to private individuals. Support is the hard one. You can still buy a multimeter or oscilloscope from Farnell or RS but Keysight won’t calibrate or repair it….
                                                    Robert.
                                                    #774222
                                                    Dave Halford
                                                      @davehalford22513
                                                      Also,
                                                      No till or card reader available invoice only.
