Faulty Chester WYV H42B6 Champion mill,
Home Forums Help and Assistance! (Offered or Wanted) Faulty Chester WYV H42B6 Champion mill,
  • #744607
    john fletcher 1
      @johnfletcher1
      My friend Brian who hasn’t a computer, has a Chester Champion Mill 20V. when recently using the mill it gave a loud bang. He brought the motor round thinking it was the problem, we tested the motor, all OK. So the fault must be with controller, has any one got a circuit diagram for the electronic controller, or knows of where a replacement board can be obtained, any other practical / useful information which might get Brian back on the road. Finally, is it better to cut his losses, fit a 3Ph motor and inverter. John
      noel shelley
        @noelshelley55608
        I take it your sure the bang was not mechanical failure ? Just a bang ? Any clues as to what has failed ? Have you seen the circuit board – are there any obvious burnt or shattered bits eg a cooked Mosfet ? As for a new circuit board have you tried Chester ? Noel.
        #744733
        john fletcher 1
          @johnfletcher1
          Thank for your response Noel. Well Brian says a bang from the control box. I notice the input filter and their caps are notorious when they fail and often give horrible smell, I’ll look there first. I couldn’t see any signs of burning or damaged Mosfets. Have large garden so busy there this time of year. Yes, emailed Chester and so far no response. John
          #744734
          Les Jones 1
            @lesjones1
            Post some pictures of the control board. (Preferably showing both the component side and the etch side.) Someone may recognise it as being the same as that used in other machines.
            Les.
            #745555
            john fletcher 1
              @johnfletcher1
              Just thought, I’d would let other Chester Champion owners know, for their possible future use, that the fault was one of the Y type capacitors shorted. The filter unit / printed circuit board was in a grey plastic holder, bolted in the bottom of the control box. On the PCB was 3 capacitors, X & two Y type and two inline chokes wound on a common core. Since having a look at other sellers of similar machines the control box looks to be the same unit, so look out for filter faults. Sorry I’m unable to take and send pictures. John
              #745557
              jimmy b
                @jimmyb
                Only issues I’ve had with my Chester 20 V clone, is the brushes being eaten!
                Had aright faf sorting that one!!
                JimB
                #745705
                Hugh Stewart-Smith 1
                  @hughstewart-smith1
                  hello John,
                  As you aren’t able to send photos if you, or your friend Brian, take a look at our Amadeal website, you might find that the circuit boards are the same and if so we would be able to help as we always have them in stock.
                  Hugh                                                         Amadeal Ltd
                  #745722
                  john fletcher 1
                    @johnfletcher1
                    To JimB, if your motor is chewing brushes they are the wrong type, a harder type is needed. Please don’t ask me where you can buy them from any longer, as  those firms have long since disappeared, as have ironmongers. With care your can re shape brushed, but it is often difficult to gain access to the commutator to bed them in, using strip of UPSIDE down glass paper, NOT emery cloth. Also, thanks to Hugh I’ll have a look, fortunately I’ve got Brian back on the road again. John
                    #758922
                    john fletcher 1
                      @johnfletcher1
                      Back again regarding Brian’s mill, After emailing the supplier and no response, Hugh from Armadale contact us and told us about a motor he had for sale which he thought would be suitable. Brian bought the motor, had to make new mounting brackets, not much of a problem for a model engineer, so now all is working. Brian now a happy man, I been asked  to thank Hugh for the service he provided. John
                      #758946
                        @hughstewart-smith1
                        John, we at Amadeal are always more than pleased to help a model engineer in distress! 🙂
                        Hugh
