Posted by Joseph Noci 1 on 09/05/2021 15:34:21:
Doubt that R2 orientation is seen by the processor at all..
Now the test –
Remove the processor from the socket, power the board, and with a wire jumper, short one of the DS lines to GND. That should light up ALL the segment of one of the digits. Repeat for the others. You van see how that works – current can flow through all the segments since the top transistor is OFF ( missing), so shorting the DS1-4 line to GND provides the current flow path.
If NO segments glow, the display is faulty, or as I have had before, its a common anode instead of common cathode device…
Thanks for yet more helpful guidance, Joe … it’s appreciated.
I wish I had seen your comment about the R2 orientation before I tried to remove it
My solder sucker needs a new [and preferably smaller] tip for work like this … so I resorted to ‘wick’
After two hours [on nine pins !] I gave it up as a bad job … most of the solder is removed, but R2 is still hanging on tight.
I tried the simplified display test, and yes … some elements of some digits light up [and the sounder beeps]
Incidentally, the display is marked HS20401K-30 but I have yet to find its data-sheet.
All things considered … I think I will just build the second kit and see how it goes.
Edited By Michael Gilligan on 09/05/2021 21:55:30
