Hi all,
A while back (longer than a warrantee period!) I bought an 6"/150mm Imperial/Metric Dial Caliper from one of the 'usual suspects'. It didn't cost a fortune and initially, it worked perfectly.
Over time I put it to one side for no real reason, except that I found myself using either my similarly sized vernier caliper or digital caliper more.
Anyway, I picked it up to use the other day and to my disappointment, I found that it no linger worked!!
It now fails to show any reading below about an inch or above 4 inches and reads sporadically between those extremes.
As far as I can see, the pinion gear, that drives the dial, is completely disengaged from the rack at the closed/open extremes of movement and is only marginally engaged between.
I have little hope of fixing it (seems a same to throw it away, though!) – the caliper dial mechanism is glued to the body & the rack is glued (and screwed) down too.
I just wondered if anyone had come across something similar before?
It seems odd that it once worked…but now, after few months of sitting in a draw it doesn't
cheers
