Let me try that again!!
I've just been facing off, to length, some 1/2 inch square bar (Columns for a Stuart James Coombes).
Faced off with an HSS knife tool, then centre drilled without a problem (Using a No.2 centre drill).
Next I set up a carbide tip tool, the indexable triangular type, adjusted the height, and then faced off a length of the square bar. When I centre drilled the bar I broke the centre drill. Decided I'd been careless. So I faced off the other end and took more care with the centre drill. Snapped the tip off.
Reverted to the HSS knife tool, no problem at all.
My assumption is that the carbide tip tool has "twisted off" the material as it got it centre, rather than shearing it off, causing it to harden.
I'll re-check the tool height, sounds best explanation, though the material didn't show any signs of a dimple and the drill didn't show any signs of wandering off. Pretty sure it's not key steel.
In terms of EN1/3 not hardening, would that hold true if I literally twisted a length until it sheared into two pieces? I'd have expected the sheared ends to be harder than the bar in it's natural state. So not hardening through machining, but by dint of being stretched beyond it's elasticity.
Hopefully, the Neurons fired in the right order this time, instead of some random sequence!
Steve
Edited By Steve Withnell on 23/03/2014 17:55:33
