Posted by Robin Graham on 10/08/2020 00:02:56:
Thanks for replies. I understand that milling is the 'natural' technique for making the ends of a bar parallel, but for various reasons it's not an option here.
Several good ideas for doing it on the lathe though – I'll experiment. I think Martin's / Gray's suggestions of turning between centres will be the first experiment – it's a technique I've never used, so it'll be fun and seems to be guaranteed to work – provided the lathe's set up correctly of course!
Robin
Posting on your ‘faceplate’ thread this morning reminded me to mention this …
For best results when turning between centres, you will [obviously ?] need to switch the workpiece end-for-end, rather than changing tools and saddle position. … You want both faces to end-up either flat or very slightly concave.
