Face turning Bronze castings – strange surface finish
Home Forums 3D Printers and 3D Printing Face turning Bronze castings – strange surface finish
Viewing 7 posts - 26 through 32 (of 32 total)
  • #458118
    Pete Rimmer
      @peterimmer30576
      If it's loose headstock bearings you could put a bit of load on it using the tailstock centre. Just get a bit of scrap ally or something and pop a centre drill hole in the face of it with your cordless. Grease up the flat face and the centre drill hole and use it as a rotating pressure pad.
      mike robinson 2
        @mikerobinson2
        Firstly many thanks to everyone for taking the time to respond. I have used a lathe since I was 16 as an engineering apprentice and I am 66 now. New things are not always better and the great news is a sharp HSS tool has solved the problem. The surface finish is good and smooth (flat) even on the interrupted cut.
        Perhaps I should have added at the start, my Super 7 was a fully re-furbished machine from Myford about 3 years ago, the lead screw is good, the cross slide feedscrew is new and cross and top slides are set well. I was able to complete by Quorn grinder without any issues.
        The insert by the way was from JB Cutting tools with a brand name of "TaeguTec" ,and I have never had an issue before, seems bronze is more troublesome than I remember. I will try to post a picture of the HSS test cuts shortly
        Thanks again to all for the support !
        #458978
        IanT
          @iant
          Hallo Mike,
          I don't use inserted cutters for this kind of work, so when facing this piece I would be using a HSS tool with zero (or negative) back rake.
          Anecdotally – I recently tried to face a bronze casting with the Diamond tool-holder that was already fitted (being too idle/stupid to change it) and for a few seconds all was well – and then the tool dug in. My old S7 has a good deal of backlash present in the feed screws – and frankly I should have known this was going to happen. A sharp, zero back-rake HSS tool cut the casting with no problems.
          If your machine is fairly 'tight', then using an insert (with positive rake?) might not dig-in quite so badly – but I wonder if something similar was going on?
          Just a thought…
          IanT
          #460238
          mike robinson 2
            @mikerobinson2
            Crazy times, crazy week. Apologies for taking so long to upload the photo showing a much better surface finish when using a HSS toolbit Vs insert tooling (which has never been an issue before)
            Least I am back on track and 2 more to go….
            Thanks again for all the advice.
            better cutting with HSS tool
            #460241
            old mart
              @oldmart
              Try the aluminium versions of your carbide inserts, they are much sharper and will work like the hss.
              #460253
              Nigel McBurney 1
                @nigelmcburney1
                Why waste your cash on carbide inserts,HSS correctly ground as I said earlier can give very good finishes and at a very low cost ,its choosing the right tool for the right job, and most hobby work only needs HSS though it does require a degree of skill .
                #460265
                Tony Pratt 1
                  @tonypratt1
                  Posted by Nigel McBurney 1 on 27/03/2020 19:17:40:
                  All engineering requires a 'degree of skill'
                  Tony
