Extra Special Subscription Gift for Model Engineers’ Workshop
Home Forums Model Engineer & Workshop Extra Special Subscription Gift for Model Engineers’ Workshop
Viewing 25 posts - 51 through 75 (of 80 total)
  • #135927
    David Clark 13
      @davidclark13
      Hi Martin
      The next page gives you the option to add the code and the one after that mentions the gift.
      Make sur it does for you.
      regards David
      Howi
        @howi
        The source code is where you enter x228, on the next page the subscription drop down box shows two options, quarterly by DD with drill chuck and arbor or annual with drill chuck and arbor.
        you can't get to this page if you don't enter anything in the source code box.
        #135941
        John Hinkley
          @johnhinkley26699
          David, to answer your question ……..
          My subscription finished at the end of December, so the last issue of MEW that I was due to receive was the December issue, which arrived yesterday by post. I renewed my subscription two days prior to that and successfully used the code that you supplied. You'll hear if the chuck doesn't arrive!
          MM57
            @mm57
            @DC1/HW…subscribed. Thanks.
            #135959
            Metalmuncher
              @metalmuncher
              I got a renewal notice in the post and I renewed online nowhere was i prompted to enter a code for a free gift. I renewed for two years as it was cheaper that way. Its a shame that loyal readers don't qualify for a gift without having to play the system.
              #136001
              Flying Fifer
                @flyingfifer
                Renewed mine today now we `ll wait & see if it arrives
                #136020
                David Taylor
                  @davidtaylor63402
                  Thanks for working on a gift for us overseas readers, much appreciated.
                  I probably would have re-subscribed anyway but the drill attachment made me even more glad to do so. I hope I there is still stock.
                  I was going to buy one of these soon so good timing for me.
                  David.
                  #136046
                  David Clark 13
                    @davidclark13
                    Hi David
                    I will try and check.
                    Probably to early to get figures.
                    regards David
                    #136047
                    David Clark 13
                      @davidclark13
                      Hi There
                      Too soon to get any figures.
                      I should know late next week with a bit of luck.
                      regards David
                      #136052
                      Chris Parsons
                        @chrisparsons64193
                        I went for the subscription the day the code was posted – but have heard (and received) nothing so far?
                        Would have thought I would at least have had the magazine, could someone check to see if I am 'on the list'?
                        Is this possible, David?
                        Thanks
                        Chris Parsons
                        #136240
                        David Clark 13
                          @davidclark13
                          Hi Chris
                          The first magazine you are likely to receive will be 212.
                          211 was already posted when the code was made active.
                          regards David
                          #136244
                            Posted by David Clark 1 on 23/11/2013 16:41:35:
                            Hi Chris
                            regards David
                            Is that right, David ???
                            I only received 210 recently , and that's dated December.
                            clivel
                              @clivel
                              When subscribing last week, I was given the choice of which issue to start the subscription with, the earliest being issue 211, Jan 2014. To be posted mid December.
                              #136303
                              Chris Parsons
                                @chrisparsons64193
                                Thanks very much, I managed to get through to subscription services and they also told me Jan 2014 – sent around mid December – according to their web page
                                212 JAN 2014 ISS 211
                                20/12/2013
                                #136319
                                  Chris,
                                  The confusion was probably caused by the fact the mailing envelopes are numbered one higher than the magazine inside.
                                  This dates back a while; to when they sent out an un-numbered "special" and now they can't get the numbers back in phase.
                                  Edited By Michael Gilligan on 24/11/2013 16:39:43
                                  #136321
                                  Peter E
                                    @petere
                                    Question to DC1; How much tolerance before/after the subscription offer has been published is there? I wonder if it would be a case to ask since I renewed less than a month before the offer was published?
                                    /Peter
                                    Edited By Peter E on 24/11/2013 16:48:23
                                    #136347
                                    David Clark 13
                                      @davidclark13
                                      Hi Peter E
                                      Sorry, if you do not quote the code you do not get the gift.
                                      Nothing I can do about that.
                                      However, if you extend your subscription for another year and quote the code, you can get the gift but you must quote the code.
                                      regards david
                                      #137009
                                      Howi
                                        @howi
                                        Freebie arrived today – the system does work………….
                                        #137011
                                        Ian P
                                          @ianp
                                          Posted by Howard Winwood on 04/12/2013 13:01:01:
                                          Mine arrived too but its got bit of wobble!
                                          I've not drilled any holes yet and I don't know what its runout specification is, so how useful it will prove to be is open for debate.
                                          Ian P
                                          #137035
                                          Howi
                                            @howi
                                            Thought I had better check mine, mine has pronounced wobble too. Measured runout on jt0 spindle and got 0.35mm – totally unacceptable. I think the chocolate nut and bolt on another thread would have more uses, at least I could eat it!!!
                                            I feel we have been duped.
                                            Anyone care to comment?
                                            #137086
                                            Gray62
                                              @gray62
                                              Received mine yesterday, apart from a tiny burr on the spring groove which was causing some binding at the start of travel (stoned it off and all good now), there is no discernable runout on this one.
                                              Suggest you guys talk to MHS (or talk nicely to Ketan at Arc) MHS should replace any faulty items.
                                              Graeme
                                              #137101
                                              Trevorh
                                                @trevorh
                                                Freebie arrived yesterday looks good
                                                no issues here
                                                #137505
                                                Ian Burton 1
                                                  @ianburton1
                                                  Hi David
                                                  In answer to my own question (and subsequent reading in the forum) yes cancel the current DD's claim the gifts renew DD's over the phone dead easy. Did n't realise I could set up the DD at the same time until told by the receptionist simple (I assumed it'd be a year subscription). However it would have been more simple to send me the gifts and ask me for the difference in subscription rates if I wanted them. I have asked for this to be passed on upwards as a suggestion. I assume that most people would be like me wanting the security of the magazines continuing and getting my magazines if they already pay by DD and so would be likely to be happy to have a short cut to getting the gifts (if they wanted them!)
                                                  PS would prefer a land line I did not have to pay for not 0844 doesn't have to be 0800 I already (like most) have free landline calls.
                                                  regards
                                                  Ian
                                                  #137613
                                                  David Clark 13
                                                    @davidclark13
                                                    Hi Ian
                                                    Getting the free gift for renewing subscriptions is bending the rules.
                                                    Best not to rock the boat.
                                                    I can't do nothing about 0844 numbers.
                                                    regards David
                                                    #138510
                                                    John Hinkley
                                                      @johnhinkley26699
                                                      My gift was waiting for me on my return from the UK on Friday last. First impressions are very favourable. I haven't used it yet but I see no reason to think it will be anything other than satisfactory.
