Thanks for the comments so far, but the main point being overlooked with alternative options mentioned, (all of which I've used at some point in my murky past), is Noise, I'd get away with short hits to grind off scruffy remains of spot welds etc, but not slitting whole panels off.
I need to remove complete panels because that's what is going back on, not patches, and ideally I want to cut around the spots to remove the panels making it easier to grind just the remaining zit of the spot welds off, plus cleaning up prior to rewelding.
The problem with car bodies too, especially when totally stripped out, is that they transmit noise like a bloody big drum!
Nibblers are ok, but they make a hell of a racket if air powered and if electric, far too bulky for the limited spaces I need to work, i also need to get up close to edges, some of which are inside a double recessed lip on the sill, and compound curves inside and on the back wheel arch.
Scruffy ragged edges from a plasma type cut are not a problem, the main panels being cut (floor and sill) are on top, and those being removed, I want to leave a relatively undamaged lower lip to spot weld back onto,
I have one sided spot welding facilities, as well as MIG, TIG and oxy acetylene, the latter I prefer not to use anywhere because of the distortion it causes.
Drilling spot welds out isn't an option i want to use but may have to consider, it's a quick bodge method which doesn't remove all spots cleanly, and would also require the holes left in the remaining panel to be welded back in again, which means more work and grinding to finish, I'd rather leave the panel whole, which would appear as close to factory fit as f*ck is to swearing,
A cut and shut job on these cars just doesn't cut it with serious buyers stumping up proper money to buy, and I will need to sell it at some point, I'd rather not have the price chipped down because someone is picking holes (no pun) in the method of repanelling.
I take the points about the 'thermic lances' spraying sparks everywhere, but all of the vid's I've seen have shown an operator lopping down stonking 2" thick steel bars, which is going to take a lot of heat, I need nothing like as big a cutter as that.
Using an electrode to cut is a possibility, but it's messy and I'm very likely to stitch the panels together in places which means more grinding, or worse, big holes blasted through the lip of the panel that's to remain!
This has given food for thought though Jason, and might experiment with the TIG. to see if it will cut locally around the spots.
JD, panels aren't cheap here either, but I'm lopping off replica colanders to fit entire new panels,so no worries there.
I'm also an avid fan of waxoyle, and 3 litres of the stuff was blasted into the O/S sill & wheelarch area with a high pressure gun, plus visible areas were etch primed, painted and then sprayed with flexible stone chip resistant coating ………..hopefully that part of the bugger won't rust away so fast, even on our (sometimes) gritted roads! ![cool cool](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
