Posted by peak4 on 30/10/2020 14:30:03:
If you want to practice scraping, rather than doing it on the back of the bed, perhaps try on a length of spare continuous cast iron bar.
That was the first thing I made on the way to re-scraping my grinder, and used it both on the flats and the dovetails.
In my case I didn't use continuous cast, but took a slice of a cast iron bus bar fishplate clamp.
Strikes me that there are two advantages there,
one you aren't changing the lathe,
and two, when you are happy enough with your technique, you will then have a straight and flat straight edge to use on other jobs.
I wonder if your front shear is more worn than usual is it was because a previous owner primarily used the lathe for boring work, where the forces were in the opposite direction to external turning.
Re. bed grinding, I gather you followed by link to Garside's machinery moving web site, but were you able to access the Facebook link.
The latter has a photo of them grinding Myford beds, and a discussion of pricing for larger work.
Bill
Bill,
That's an interesting theory about the boring operations. The thing is, the lathe always seemed in pretty good overall condition for its age (0.002" wear on one slide isn't huge I don't think for a 54 year old machine), and the person who owned it immediately before me used it for making steam engines and narrow gauge locomotive models, so a range of turning jobs. It's history before that is unknown of course.
I couldn't get any information from the Garside website or Facebook page, but gave them a call. I am sending some photographs and my measurement data by email, and they said they'd get a price for me.
I have to say though, I spent about 5 minutes with a fine file earlier on this morning, used very gingerly flat-on to the face, and already I can get the saddle to more than 3/4 of full travel with no significant tight spots or play. This amount of work didn't even bottom out the machining marks on the right side of the bed, yet it seemed to make a huge difference. I could feel (but not see) a very slight roughness along the top corner of the vertical slide, which I smoothed off. I wonder if that was contributing to the issue somehow?
My intention is to now do a much more detailled filing, measuring and flatting session, remove the saddle steps (not that I can actually see or feel anything significant), fit the new gib strip and re-evaluate.
I'm currently a lot more optimistic about being able to sort this out myself than before. I was always surprised that less than 0.002" would cause the degree of binding I was experiencing.
