Hi Doc, That's interesting and certainly seems to fly in the face of 50+ years of experience by Myford owners doing the wide guide conversion. Plus a host of Drummond owners doing the equivalent mod with success. I cant imagine why wear would be on the gib side of the front vertical surface rather than the load bearing rear face of the front way. Maybe if the gib strip was run over tight? Or left so loose the whole carriage pivoted so it would bear on one corner of the carriage and it wore badly, Or cast iron swarf etc embedded in the steel gib strip abraded the bed? Seems very odd.
Not quite sure if you have some accumulative error in calculating rather than measuring the gap between inner vertical faces perhaps?
But, what you need to do is first double check your measurements and then try to confirm them by a second method. So far you have assumed the rear face is perfectly flat, straight and unworn. I would run a 10" fine flat file over it to make sure it is clear of burrs and the gummed up oil of ages. Then carefully inspect it for any signs of wear. Original curved machining marks should be visible all along it. Then I would double check it with a straight edge and feeler gauge. Even a simple steel rule would suffice if used carefully and of good quality. The thicker rule out of a combination square set works well for this.
Then ditto for the front vertical surface. Run a fine file over it. If its worn like you have measured thus far, you should be able to test it with the steel rule and thin feeler gauge, say the 1.5 thou that most sets go down to.
And ditto for the rear vertical surface of the front way. A straight edge and feelers should show up any wear here.
Then recheck all your micrometer readings again.
If your mike readings and straight edge and feeler gauge readings confirm there is 2 thou wear on the front vertical surface and none on the rear, it is still within Myfords 3 thou recommended limit before a regrind. So its up to you if you want to spend the time and effort on a regrind. And money. It depends on how the lathe is in use.
A lot can be done by following the ML7 owners manual and adjusting or shimming the mounting feet on the tailstock end of the bed to get the lathe to turn parallel over a 4" length of 1" diameter bar held in a GOOD chuck with no tailstock centre in place. If you can get it within say half a thou or so, that might do for most home hobby work.
And you can always use the time honoured method of a touch up with emery paper to knock the last half thou off a job and get a nice finish at the same time.
That said, it would be good if you could really confirm there is no wear on that rear surface of the front way. Straight edge and feelers would be the easiest way. But the way machine tool fitters often do such things is to make up a "sled" that slides along the bed, with two pins that locate on that unworn rear vertical surface of the back way and then a dial indicator is mounted on the sled and takes a reading off the vertical rear surface of the front way. Sometimes you can use an old time marking gauge for this. They had two small dowel pins that could be tapped down to protrude from the flat bottom surface of the guage for this purpose. Or if you fit the wide guide strip to the saddle, the saddle itself can be used as the sled, with the strip bearing on the rear surface and a dial guage mounted to the saddle bearing on the front vertical surface. I may have a pic of how I did that somewhere if I can find it and post it later.
PS. If you have copies of the Measuring Bed Wear ariticle there are pics there of using the marking gauge base and a DTI to measure variation between the rear unworn surface and the worn front vertical surfaces. This would be a really good thing for you to do before spending money on a regrind.
Edited By Hopper on 28/10/2020 10:47:50
