All, I finally got around to measuring the ML7 beds today, using some borrowed micrometers.
I noted the measurements as per Pete's article instructions.
Disclaimer: this is the first time I've done this, so I may have made incorrect assumptions!
So the first assumption is that the rear vertical face of the rear bed is totally unworn, ie straight left-to-right. This is my "reference" surface for overall widths and calculating other stuff.
The second assumption is that "wear" is the difference between the largest and smallest measurements of a particular area. Seems valid w.r.t. Myford's dimensions, compared with the least used bits of the beds.
Anyway, on the evidence of just the raw data, all the wear is within the stated limits for re-grinding, and – I'd hoped – for the wide-bed conversion…
I then put the data into a spreadsheet, and plotted graphs of the measurements at the 1" spaced 24 points along each bed. The individual graphs are here:
The scatter here is probably due to the tiny differences in width
I then calculated the gap width between the two beds. Seemed reasonable – more wear at the tailstock end from moving it backwards and forwards, but nothing massive:
I then plotted graphs that represent a plan view of the rear and front beds, with their actual width variations exaggerated, and this is what I got:
So, unless I've made an error somewhere, my lathe seems to be an anomaly according to Pete's article, becasue it seems to be the front of my front shear that's worn, not its rear. This appears to be confirmed because the overall bed width and front bed width graphs are pretty much the same shape. Anyway, it is what it is.
So the question is: in view of the fact that my lathe appears to have a uncommonly worn front vertical shear (no idea why, as far as I know it was only ever used for model engineering), is it even worth considering converting it to wide bed? I can't see it will make any difference if I've understood the method correctly?
So is the only option a re-grind, since it seems to be within limits for that?
Thanks all.
