Hello Don,
The article was published in 2 parts Volume 158 # 3794 6 february 1987 and # 3796 6 March 1987.
The plans were given the number WE88
I recommend a few improvements;
1. Make a holder for a 4 jaw chuck to grip a boss for turning the eccentrics on the mandrel, a much more satisfactory way of holding things for intermittent cutting than between centres using a catch plate and drive dog. It also makes offsetting for the throws so much easier. Drive the whole thing from that boss when in use for gear cutter making.
2. Fit brass bearing surfaces to both the anchor plate bore and those of the indexing sleeve, furthermore lubricate with EP80 gear oil [don't ask!]
3. Harden the pawls and fit each one with its own individual eccentric mounting, setting up the timing later is a lot easier
4. Notch the indexing teeth on the sleeve to help hold the indexing pawl engaged when operating, it tends to jump out on notches cut as shown.
Those were the main improvements I found helpful. I attempted to make standard size gear cutters using the device, but sadly it wasn't up to that duty and eventually found another way but I imagine it would work for the size of cutter [1.25 inch diameter] Ivan Law built it for.
I hope that experience helps you.
Regards Brian
Edited By Brian Wood on 05/05/2014 09:35:32
Edited By Brian Wood on 05/05/2014 09:36:37
