Posted by John Pace on 29/04/2020 19:11:49:
Hi Michael
My Mitutoyo is not so good on battery life as that but carries on working
showing the B sign and gradually the display fades ,the caliper above
the Mitutoyo i think was from Arc euro is a good caliper but the battery
life is very poor ,the other two also cheapy's have much the same fate.
The micrometers you can't turn off they go into a sleep mode which
drains the battery …
My pet theory is that poor battery life is caused by a combination of condensation and cheap calipers being very voltage sensitive. Measuring my various digital calipers showed they all consume about the same constant current when switched 'off', less than 10 microamps. Whatever causes the problem, it isn't being left 'ON'.
Energizer quote a capacity of 130mAH for their CR1632, that being measured at 19mA for 684 hours, taking the cell from 3 down to 2V. At 10 microamps, a CR1632 should last many years in a caliper apart from life limitations l due to internal decay, hence best before dates.
However, my cheapo Lidl caliper fails long before the cell is truly flat! A drop of 0.5V is enough to stop it working.
Also, cheap calipers are poorly sealed against moisture. They are much more vulnerable to condensation than a quality caliper with an IP rating.
So I suspect a little used cheap caliper kept scrupulously dry will get much better battery life than the same caliper well used in an ordinary workshop. The posh calipers are sealed against condensation and I guess their smarter electronics get more life out of cells by being less fussy about low volts.
Just a hypothesis – needs to be tested!
