ER32 Extension
ER32 Extension
Home Forums Workshop Tools and Tooling ER32 Extension
  • #657329
    Neil Lickfold
      @neillickfold44316
      There was a company on Ali, that was selling a bearing nut for ER32 and smaller. Nothing to catch your hand on if you cover the area between the nut and the body where the extra thread is. In China and else where , they are making these bearing spanners that have either a lever or switch for the different directions, or else you need to turn the spanner over. They make the matching Nuts and spanners for the ER16 and the SK models, up to ER32 or the equivalent . An ER32 nut is 70mm diameter I think it showed, I have some and they work very well. Will get some more in the future. A lot of brands are making the one way bearing spanner now. BIG make them for some of their range, in particular the mini collet holder, for holding the drills on a 1.5mm shanked drill bit and the smaller 0.8mm shank series drills or cutters etc
      A search for Bearing wrench , will show up the results.
      Brendan Gill
        @brendangill16097
        harsh comments in here for a typo and quick post I made…
        Came back to make a correction.. my collect chuck runs 6 thou excentric runout. (got my imperial and metric mixed up again)
        Its still a lot for a collet chuck without a collet fitted.
        #657438
        Emgee
          @emgee
          Brendan
          I think it's because of the spectacular word, I don't ever recall that word being used to describe the quality of a tool so something that is different stands out.
          Don't loose sleep over it.
          Emgee
          #657449
          Graham Stoppani
            @grahamstoppani46499
            Posted by Martin Connelly on 13/08/2023 08:52:52:
            You can always stick a square collet block into a 4 jaw chuck and dial in the required concentricity. Arc Eurotrade sell all sizes with and without nuts and all have a through hole. I would make a setting bar with an accurate centre drilled in one end to ensure the positioning of the block is along the spindle axis.
            Martin C
            I've just done this for a job where I had to face, drill and tap 90 aluminium rods each end and can confirm it worked a treat.
            Graham
