ER32 collet use.
ER32 collet use.
Home Forums Workshop Tools and Tooling ER32 collet use.
  • #191245
    Maurice Cox 1
      @mauricecox1
      Is there a minimum length that can be gripped in an ER32 collet please? I'm an old dog learning new tricks. I'm less concerned about the work moving, than damaging the collet. Also, I wish to purchase a holder to mount the collets on my Myford. RDG Tools and Arctrade Euro both advertise them for around £45. Axminster tools stock one in a wooden box complete with the three screws an a "C" spanner, for just over £100. None of the firms mentioned seem to make any claim as to the standard of accuracy to expect. Has any one any comments please?
      Regards Maurice
      Maurice Cox 1
        @mauricecox1
        #191249
        Thor 🇳🇴
          @thor
          Hi Maurice,
          As far as I know the cutting tool (or bar) should preferably be inserted the full length of the collet or at least 2/3 of the length. Here is one website giving info about ER collets and their use.
          Thor
          #191253
          Simon Collier
            @simoncollier74340
            You can hold a short length if you put a length of bar of the same diameter of the workpiece in the collet first. I did exactly that an hour ago.
            Simon
            #191254
            Bill Pudney
              @billpudney37759
              I would agree broadly with Thor.
              Some of the smaller ER32 collets have the nominal bore size finishing part way through the collet, that is (say) 10mm collet has a length of 10mm diameter maybe half the length (say 20mm) of the collet. I generally try and stick enough material up the spout to at least the end of the nominal size, ….if that makes sense.
              cheers
              Bill
              #191257
              mechman48
                @mechman48
                Thor
                Check your link… I tried it & came up with a virus threat…
                George.
                #191259
                Johnboy25
                  @johnboy25
                  Thor… That's a useful site – thanks for that. I've filed it away in my 'Useful info' file.
                  The info's out there – just got to find it!
                  Gary Wooding
                    @garywooding25363
                    My Avast (anti-virus) program blocked Thor's site: said it contained malware.
                    #191261
                    Leo F Byrne
                      @leofbyrne36951
                      My AVG programme also kicked in.
                      Leo
                      #191267
                      KWIL
                        @kwil
                        The optimum insertion length would be to the full depth of the bore griping surface, noting that some are recessed at the rear, any less a length, although possible, runs 2 risks.
                        Firstly you may strain the collet because of the lesser engagement length and secondly, you will not get the maximum grip available. You takes your chance.
                        #191279
                        Anthony
                          @anthony
                          I bought a set of ER25 collets and chuck for my milling machine from RDG at the Harrogate show this year, and as an afterthought also purchased their collet chuck for my Myford Speed 10. The instructions for machining and fitting the two parts of the chuck together are on their website, and are very easy to do. I am as pleased as punch with my purchase, and would definitely use RDG again.
                          #191289
                          David Colwill
                            @davidcolwill19261
                            Nod 32 also flags it.
                            David
                            #191295
                            Maurice Cox 1
                              @mauricecox1
                              Thanks for the feedback gents. Much as I assumed. Just got to decide where to get the nose piece from. Thanks again
                              Maurice
                              #191301
                              Vic
                                @vic
                                I've worked on small items with only 5 or 6mm in the collet without any problems. It's worth mentioning that whilst the larger size collets may grip over the full 40mm depth the smaller sizes don't. Taking a random collet from my set the 6-5 collet only grips over 25mm.
                                #191304
                                KWIL
                                  @kwil
                                  The "nose piece" from ARC which includes a bearing to lower the effort required to close and open collets is worth looking at. Much easier.
                                  #191329
                                  Maurice Cox 1
                                    @mauricecox1
                                    I have just looked at RDG's webpage for the Myford collet chuck. It includes the fitting instructions which say " clean up the backplate, fit the chuck but do not fully tighten the screw. Check the taper for accuracy. If there is a high spot, tap it to correct it. Tighten the screws". Really? What happened to turning the backplate to be a close fit in the register? It does not inspire confidence it the product.
                                    Regards Maurice
                                    #191337
                                    Enough!
                                      @enough
                                      I was going to say why not use the Soba type which doesn't use an intermediate backplate but the ER32 version seem to have disappeared off the shelves since I got mine some years ago.
                                      Odd because the ER25 version is still around.
                                      #191340
                                      KWIL
                                        @kwil
                                        WARCO still have ER32smiley
                                        #191341
                                        Enough!
                                          @enough
                                          Don't see it on their website KWIL … just ER25.
                                          #191351
                                          Thor 🇳🇴
                                            @thor
                                            I understand the website I linked to raised the antivirus flags for some of you, sorry for that. George, I run AVG myself and didn't get any flags raised when I visited the website, also tried just now, and still no reaction.
                                            Thor
                                            #191352
                                            Oompa Lumpa
                                              @oompalumpa34302
                                              Antivirus software is not perfect, there is no problem with the page (though I do like the screenshot above saying the "threat" had been removed, that is quite funny) your antivirus software probably needs an update.
                                              However, accept everything I say about antivirus with a pinch of salt, I am still apologetic to someone here about this sort of thing though I am usually on the ball.
                                              graham.
                                              #191357
                                              KWIL
                                                @kwil
                                                Warco part number 9027
                                                #191397
                                                Enough!
                                                  @enough
                                                  Posted by KWIL on 27/05/2015 09:24:41:
                                                  Not the same thing, Kwil – it's the same type everyone else is talking about and needs the intermediate backplate. ….. see the link in my earlier post for the Soba type that I was referring to that screws straight on … (albeit only in ER25 now apparently).
                                                  Edited By Bandersnatch on 27/05/2015 18:10:23
                                                  #191439
                                                  Flying Fifer
                                                    @flyingfifer
                                                    I have an ER32 Collet chuck made by HBM which screws directly on to the Myford spindle. I`m certain I bought it from RDG but there is absolutely no sign of it anywhere on their site. Nor can I find any reference to it anywhere else on the web.
                                                    I`ve had a dig around on the net & found that Harold Hall has complete instructions on making the same type of chuck (and ER32 as well !) on his website. Nice little project & not to difficult.
                                                    Alan
                                                    #192535
                                                    Maurice Cox 1
                                                      @mauricecox1
                                                      After some thought, I purchased a 400mm ER32 collet chuck and a suitable Myford pattern back plate, from Arc Trade Euro. I have just finished machining and fitting it. On testing the internal taper at several points, I found the maximum runout to be about half of one tenth of a thou! Very pleased with the result. I have no connection with Arc Trade Euro, other than as an occasional and very satisfied customer.
                                                      In order to fasten the chuck to the back plate, I required three screws. I went to Apex Fasteners on Slough trading estate in Berks. The chap that served me found the correct screws for me, didn't complain when I changed my mind about the length, and when I came to pay for them he said "put fifty pence in the Poppy Appeal Box". I gladly put more than that in. What a great firm! I have used them for several years now and they are so helpful, knowledgable, and have no minimum charge. I know that few readers of this forum will be able to use them, but I just wanted to say how great they are! Such a refreshing change. Again, I have no conection with them.
                                                      Maurice
