er32 collet holder
er32 collet holder
Home Forums Model Engineer. er32 collet holder
  • #120921
    Notlob
      @notlob
      I have a warco vmc milliing machine. The problem is on this machine is the spindle b
      e locked, my er32 chuck just rotates with the spindle.. Anyone gt any solution to this.
      Edited By Notlob on 29/05/2013 16:17:11
      Notlob
        @notlob
        #120922
        Chris Heapy
          @chrisheapy71135
          There should be a hole in the body of the chuck to accept a bar – I use a screwdriver pushed through. Hold it with that whilst you tighten the nut.
          #120924
          joegib
            @joegib
            Posted by Chris Heapy on 29/05/2013 15:54:15:
            There should be a hole in the body of the chuck to accept a bar …
            — or 2 flats on the chuck body to take a spanner. You hold that element with one spanner and tighten the nut with another spanner (either a conventional spanner if the nut has flats or a C-spanner if it has notched indents).
            Come to think of it, machine spindles that have a locking mechanism are the exception rather than the rule.
            Joe
            Edited By joegib on 29/05/2013 16:19:48
            #120925
              Or a knurled ring on the holder body which you hold with one hand and a C spanner on the nut which is what I have.
              J
              #120926
              Notlob
                @notlob
                The chluck body has no flats, it is just round
                And my bridgeport the spindle can be locked
                Edited By Notlob on 29/05/2013 16:21:52
                Edited By Notlob on 29/05/2013 16:35:12
                #120930
                Les Jones 1
                  @lesjones1
                  Hi Notlob,
                  How do you prevent the spindle turning when tightening the draw bar ?
                  Les.
                  #120931
                  Windy
                    @windy30762
                    I have a Warco VMC with a ER32 chuck supplied by them and no means to lock it when tightening the nut.
                    It is not like a Vertex one I have with spanner flats (different taper)
                    I used a carbide end mill to create some spanner flats on the Warco ER32 chuck.
                    Paul
                    #120933
                    Notlob
                      @notlob
                      And I was a toolmaker for 35 years
                      #120936
                      Notlob
                        @notlob
                        When I pointed this out to Warco their reply was ther is no way to lock the spindle so tough
                        #120940
                        Tony Pratt 1
                          @tonypratt1
                          On my Myford VME vertical milling m/c there was no means of locking the spindle so I made one! Underneath the large front pulley there are a series of what I presume are balancing holes, it was a simple matter to knock up a block and sliding pin to locate in one of these holes whilst tightening the draw bar.
                          It may be that the Warco VMC has something similar?
                          Tony
                          #120946
                          Notlob
                            @notlob
                            I probably will have to buy another collet holder one with spanner flats
                            #120952
                            Mustafa B. Adday
                              @mustafab-adday34743
                              I never tighten my collet chucks in the machine. Either using a dedicated holder (screwed to the bench) or the vise with alu jaws.
                              regards, M.B.A..
                              Oh, that speeling!
                              Edited By Mustafa B. Adday on 29/05/2013 19:31:25
                              #120956
                              Old School
                                @oldschool
                                Notlob, You should be able to hold the spindle with an oil filter type wrench with a rubberised fabric strap.
                                #120959
                                Trevor Drabble 1
                                  @trevordrabble1
                                  Notlob,
                                  I faced exactly the same problem as yourself with my ER32 holder, but since one of the reasons I chose my Myford VMB milling machine was because of the 3000 RPM top speed, the solution was relatively simple. I modified an R8 stub arbour to accept a grinding wheel I had in stock , then set up the collet holder vertically onto an angle plate on the milling macine table, protected all exposed machined surfaces, installed a front safety guard for myself, and then, ensuring I was below the MOS, ground a pair of flats on the holder body to suit a Clarkson collet chuck spanner I had in stock.. One thing I did particularly ensure was that I only presented the holder to the wheel AGAINST the direction of rotation since I did not want it to grab.
                                  Hope you will find this info of some use.
                                  Trevor.
                                  #120994
                                  Gone Away
                                    @goneaway
                                    My ER-25 chuck has the same problem. At the top of the mill there is a tubular nut with flats on it that the drawbar jacks against when releasing. I used to do that nut up as tight as I could and hold it with a wrench when tightening/loosening the collet nut.
                                    That was OK when tightening the collet nut of course. As with all my ER chucks, I don't overdo the chuck tightening – just a little nip – nonetheless at intervals when loosening the collet nut, the top nut would loosen and I'd have to remove the whole chuck and put it in the vice with soft-jaws to undo it.
                                    Then I bought an ER-32 chuck which had proper flats on it which I prefer anyway since the size range suits me better and I rarely use the ER-25 any more.
                                    Edited By Sid Herbage on 30/05/2013 02:08:40
                                    #121061
                                    Sub Mandrel
                                      @submandrel
                                      is the body of your chuck hardened? If not, why not drill three holes for a tommy bar?
                                      If it is hard, a carbide drill might still drill it.
                                    Home Forums Model Engineer. Topics
