Hi guys, I'm after a little bit of advise please.
I bought an ER32 collet set some months ago for my mill, and thought it would be good to use them in the lathe also (Myford ML7)
I bought a 4" collet chuck and blank back plate from Arc Euro, and I've machined a shoulder on the back plate to be a tight fit on the recess in the back of the chuck. I then used a transfer punch to mark the through holes in the back plate. This is all bolted together with 3 M8 socket cap bolts.
Now, when I put a dial indicator against the flat area behind the collet nut, it's true to less that 1thou, but, when I fit a collet and some ground rod (silver steel) it is out by 15+ thou!!
So my question is, how accurate are collets? I assumed they would be almost spot on every time. Should I machine the shoulder on the back plate smaller by 5-10thou and the set the dial on the ground bar stock and tap the chuck till it's true and then nip up the M8 back plate bolts?
Thanks for any advise, cheers, Rob
