Ian,
You`re very welcome. At the time when Harold did the original article in MEW I didn`t have any ER collets though I was seriously contemplating getting them but didn`t know which size to purchase.
Studying the article & the prices of 5C square collets convinced me to go for ER32 collets mainly because they were larger than ER25 so I could make shall we say bigger square collets ( & also by the way Rectangular collets) than would be possible in the smaller sizes of ER collets.
I used 12mm Sq steel bar for my collets, cutting 4 x 90mm lengths cleaning the inside 2 faces before stacking & loading in the four jaw & turning the OD to 23.5mm. I then faced off the end & turned a length of 40mm down to 19.5mm dia. I then turned a groove to accept a circlip at the shoulder. Removed 4 jaw, fitted ER chuck with 20mm collet, fitted first embryo collet into said chuck & repeated above. I then parted off in the centre of the 23.5mm dia & cleaned up the faces of the 2 embryo collets. I then stamped each jaw 1,2,3 & 4 so that I could keep the jaws in the same position in relation to each other.
I repeated the above a few times so I`d have ready made blanks if I required different sizes. Must admit they have come in very handy
Alan
