Er collets ?
Er collets ?
Home Forums Workshop Tools and Tooling Er collets ?
  • #128428
    Trebor
      @trebor
      I'm after a set of Er40 collets and not sure which ones to get. Rdg do sets, Gloster tools, Chronos have sets along with Vertex ones which are supposed to be better quality. Any advice welcomed.
      Will also need to make a Lathe er collet chuck. Could you tell me a good place to buy enough EN8 bar to do the job.
      Trebor
        @trebor
        #128429
        Russell Eberhardt
          @russelleberhardt48058
          I've bought some er32 collets from these guys and they seem as good as any: **LINK**
          They do also sell ER40 size.
          Russell.
          Edited By Russell Eberhardt on 02/09/2013 14:48:32
          #128435
          Jo
            @jo
            For quality look for the value they quote as the TIR value: the smaller the better, 0.0002" is good. If they don't quote it. don't be surprised if it is not very good.
            Jo
            #128437
            Trebor
              @trebor
              Would that be a total run out figure ?
              #128439
              Trevor Drabble 1
                @trevordrabble1
                Suggest you give Dave of D&J Workholding **LINK** a call. Very helpful chap. Most certainly not the cheapest, BUT excellent German quality options and massive range incl ER 40. They also do many types of holders including parallel and MT. Suggest better to buy than to start making.
                Edited By Trevor Drabble on 02/09/2013 16:08:05
                #128440
                Trebor
                  @trebor
                  That link flashes up as a phishing website crook
                  Edited By Trebor on 02/09/2013 16:16:50
                  #128441
                  Gone Away
                    @goneaway
                    Not really. The link expands to http://sales@djworkholding.co.uk which seems to be an employee login to the site and demands credentials.
                    Try it again without the ' sales@ , part
                    #128442
                    Trebor
                      @trebor
                      #128456
                      Stephen Benson
                        @stephenbenson75261
                        Another vote for CTC Tools very good quality excellent price certianly good enough for clock repair they take a while to arrive a couple of weeks normally but then they are coming from Hong Kong.
                        #128457
                        John Hinkley
                          @johnhinkley26699
                          Trebor,
                          I'll second Russell's suggestion. I bought an ER32 MT3 collet chuck and ten collets from them in July. Cost me £66.25 including courier delivery. They arrived on my doorstep (in France) four days after placing the order. I assume they'd take the same for the UK, if that's where you are (no profile). If you email them, they'll send it by post, I imagine – but it'll take a lot longer. The ones I bought weren't the low runout jobs but their precision far exceeds what I can acheive with my experience on my equipment!
                          Gone Away
                            @goneaway
                            I too have dealt with CTC for some years now …. all of it good.
                            If you prefer, you don't have to work through eBay – you can deal direct through their website
                            #128462
                            Rik Shaw
                              @rikshaw
                              Bought ER25 collet set from RDG, very accurate and a good price
                              Rik
                              #128465
                              John Haine
                                @johnhaine32865
                                I bought mine from http://www.colletsdirect.co.uk/
                                #128502
                                Trebor
                                  @trebor
                                  Thanks for the advise chaps, I still can't decide which ones to go for . I,m hopeless.
                                  #128503
                                  Trebor
                                    @trebor
                                    Posted by Jo on 02/09/2013 15:33:46:
                                    Jo
                                    I,m unsure what the TIR stands for, is it a total run out ?
                                    #128505
                                    Keith Long
                                      @keithlong89920
                                      TIR = Total Indictated (or Indicator) Runout ( I always knew it as Total Indicated Runout)
                                      It is the absolute value of the difference between the high and low reading as seen (usually) on a dial indicator, but could be measured by other means.
                                      Measured practically it will include the effects of eccentricity as well as out-of-roundness, roughness etc.
                                      For a collet I would expect it to relate to the bore of the collet when correctly mounted in it's holder.
                                      The lower the figure the better really BUT the higher the price will be.
                                      Keith
                                      #128508
                                      jason udall
                                        @jasonudall57142
                                        TIR always intrigued me..at what projection is that quoted for…
                                        If collet is say absolutely ( ) true but has say 2 thou runnout..then center of tool will describe a circle 2 thou in diameter…hole drilled will be 2 thou larger than expected ( right! your drill /cutter is that well ground. .. you wish ) if on the other hand the collet holds non parallel. .the effect will now vary with “depth” ()
