Terry.
Yes and Yes.
I have read various forums about the gripping qualities of ER collets or lack of, in some cases but I have never come across it.
Just up the road from me is an Aerospace CNC machining company, they have about 30 CNC machines including some very large ones that do wing spars for Airbus and Boeing.
These start off with a slab of alloy 2 metres by one metre by 300mm which is loaded with a fork lift truck.
Eleven hours later one guy lifts this thing off on his own ! It uses about 30 tools to do this and runs unattended and also thru the night.
The profit margins on this job as so low they cannot afford to put an operator on it, aerospace is a very cut throat business. All the tooling is held in ER32 collets, in fact other than a bit of ER40 and the odd ER25 they have standardised on ER tooling.
If there was something better for the price, I’m sure they would be using it.
Clarkson’s are good but have been pushed out of the market by the modern chucks which are more freely available, cheaper and fit in with the tooling makers better.
No having to grind threads onto shanks and no wasted material making only 4 sized shanks regardless of what size cutter is needed. It’s cheaper to buy say a 4mm or 5mm cutter with a 4mm or 5mm shank than one at 6mm and ground down but where are the 4mm and 5mm collets in Clarkson type ? They don’t exist.
Industry drives prices.
And industry is using solid carbide and don’t want to waste time or material making cutters to fit an obsolete holding system. Long – short.
John S.
