Hi there I thought this information might be useful to others.
I recently bought an ER20 collet adapter for my Myford Super 7 lathe from RDG Tools. The box contains a threaded adapter for the lathe mandrill, a collet body and a collet nut.
What you are supposed to do is screw the adapter to the lathe mandrill then turn down the boss of the adapter to match the collet body (I also put a small relieve at the base of the register). I then screwed the body to the adapter and measured the run out.
I was getting 12 thou runout. I took the collet body off and measured the register it had less than half a thou runout.
I then refitted the body but did not fit the screws supplied with the kit. No runout. I then tightened the screws (carefully) and I got the 12 thou runout again. I then got three screws from my stock and fitted them, no runout. I then looked at the screws that came with the kit and noticed that the heads were not parallel with the threads. I throw them out. Job done and now less than .5 of a thou runout.
I just thought this maybe useful to someone else.
Bob
