Epoxy Concrete CNC Mill Design and Method
Home Forums Workshop Techniques Epoxy Concrete CNC Mill Design and Method
Viewing 2 posts - 1 through 2 (of 2 total)
  • #67727
    John McNamara
      @johnmcnamara74883
      Hi All
      I have been working on the design of Vertical mill based on Epoxy concrete
      The highlighted cube shown below is 500 X 500 X 500 mm, not a small machine but it may be scaled down. The same principals can be used on other machines.
      The Flat surfaces are cast on a surface plate with containing formwork.
      This is the first draft and it is a bit rough. All the major parts are in place. I will post updates as the design evolves.
      A power point presentation of the design objectives can be found here (2MB):
      All the Cad Files for the project including the above power point can be found 5 MB here:
      Cheers
      Edited By John McNamara on 30/04/2011 08:21:05
      Edited By John McNamara on 30/04/2011 08:22:18
      Edited By John McNamara on 30/04/2011 08:23:06
      Edited By John McNamara on 30/04/2011 08:28:09
      Edited By John McNamara on 30/04/2011 08:28:39
      John McNamara
        @johnmcnamara74883
        Powerpoint and cad files
