Engineering plastics
Home Forums Workshop Tools and Tooling Engineering plastics
  • #124827
    AB658
      @ab658
      I need to make a replacement bush for a glass top patio table, to locate the umbrella. The original plastic one has shattered with UV action over many years. Nylon 6,6 has been recommended. I need a piece of min. dia. 75mm & 50mm long; Metal & Plastic don't go that large and I don't want to buy more than I need. Does anyone have any suggestions for a UK supplier (I'm in the south-east if collection would help)?. Adrian
      AB658
        @ab658
        Small quantity of Nylon 6,6
        #124828
          Have a look at ebay seller benchrisseb
          Hopefully, this will link to the "shop"
          Edited By Michael Gilligan on 17/07/2013 16:50:03
          #124833
            M-Machine do it in 75mm for £3.60 per inch and will cut to length, page 17
            J
            #124836
            Gone Away
              @goneaway
              I wouldn't get too hung up on Nylon if you're having difficulty getting some. It's only one possibility. Delrin or UHMW would do as well if you see some. You can often find the latter as sheet offcuts, sometimes quite thick.
              #124837
              Boiler Bri
                @boilerbri
                We us Ensinger at Manchester, they have branches all over i think.
                They will put you a box together of offcuts for £25. Real baragin.
                #124838
                AB658
                  @ab658
                  A variety of good suggestions; thank you to one & all. Adrian
