Posted by Rik Shaw on 21/06/2013 20:01:59:
I like the way they used to use wood (lignum vitae) for ships prop shafts bearings… , — Rik
They still do. Submarines still use lignum vitae for the stern tube bearing, quiet, long lasting and lubricated by sea water. Not sure about surface vessels these days though.
And neatsfoot oil — I always did wonder what happend to all those poor neats hopping around with no feet.
When I was an apprentice, an old merchant navy ex-stoker told me to pee on your hands if you get blisters from shovelling clinker, or from pulling a cleaning brush through a million boiler tubes. It did not seem to me that it made much difference though. He did teach me how to repack a leaking valve using a string from the boilerhouse floor mop for packing. That one worked ok.
And my old man was so tight he used to use treacle or Golden Syrup for gasket cement on his motorbike, and sealed leaking intake manifolds by applying treacle to the outside of the manifold with the engine running, and then throw a hand full of dust over it while revving the engine "to suck it in and get a good seal".
