Engine indicators
Engine indicators
Home Forums Stationary engines Engine indicators
  • #3177
    Maurice Cox 1
      @mauricecox1
      Maurice Cox 1
        @mauricecox1
        Can anyone please tell me the diameter and pitch of the threads in the bushes on full size engines, into which an indicator is fitted? I wish to add this feature to a model I am making, even though it will not be used, and would rather not guess the size. Thanks.
        Maurice
        #119769
        Gordon W
          @gordonw
          Can't help I'm afraid, 'Ive only fitted 2 indicators to two engines and the threads were compltley different. and can't remember either of them.
          #119771
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Hi Maurice – above link is to a huge and fascinating site covering many topics about steam engines . May take some finding but in there somewhere there are technical drawings of indicators .
            MikeW
            #119772
            MICHAEL WILLIAMS
              There are also scaleable illustrations and catalogue pages .
              Some indicators that I've looked at in the past had universal fittings – a loose union nut on the indicator which joined onto a double male ended fitting in the engine cylinder . The double male ended fitting could be a supplied part or I suspect in some cases a rapidly made DIY job to mate indicator with any available hole .
              MikeW
              #119777
                This book may throw up some sizes, not had a chance to look all the way through it.
                Prestons always have a few for sale but don't give sizes.
                J
                #119790
                Trevor Drabble 1
                  @trevordrabble1
                  My Dobbie McInnes indicator has a 1.064" dia x 16TPI male thread on the bottom of the body, which I believe may be a Pg 21 conduit thread. Included in the set is a separate threaded removable collar for fitting the body to the engine. This collar has a matching internal thread to the body for half its length, whilst the other half is threaded to accept a 1.171" dia x 10 TPI whitworth form thread.
                  Hope this helps.
                  Trevor.
                  #119945
                  Maurice Cox 1
                    @mauricecox1
                    Thanks for the feedback gents. I thought they would be about one inch diameter, so I think I will go with the size described by Trevor.
                    Thanks again, Maurice
                  Home Forums Stationary engines Topics
