Posted by Jeremy Paduano on 12/06/2021 10:07:54:
Thanks everyone. I think you all saw through my slightly garbled question 👍 and answered what I was actually talking about – using the lever to engage the half nuts. (It’s so much better when I know the right terminology to describe what I mean!) I now know that I can safely engage the lever with everything still running – result 😁
Thanks again everyone. Hopefully at some point in the future I’ll be able to contribute as well as ask questions.
Jerry P.
It's a good question! Although OK to operate the half-nut lever when the machine's running, the same can't be assumed of the gearbox, if it has one.
My WM280 has the usual collection of change gears on a banjo plus a built-in 3-speed gear box, with reverse and so forth. The gear box is crude, and although it can be changed in motion, it's not a good idea. On mine it's sometimes necessary to feel for alignment by turning the spindle to and fro gently by hand. Other lathes have an elaborate gearbox able to produce many different thread pitches. I believe most of these are also meant to be stopped before changing gear, and only the most expensive lathes are happy to change gear at any speed.
Gearboxes are funny things. Gears can be changed at high-speed provided the teeth happen to mesh at just the right time, mostly luck and maybe there's a knack to it. Unfortunately gears are likely to be damaged every time spinning teeth don't quite mesh properly, and the ill-effects can range from gradually increasing wear due to mild near-misses to a tooth removing, key shearing, axle bending crash. Lathe gearboxes are simpler than car gearboxes. The latter are specifically engineered to match gear wheel speeds before attempting to mesh. Even so I occasionally crunch mine. Blush.
