Endmill smear of metal
Home Forums Beginners questions Endmill smear of metal
Viewing 3 posts - 26 through 28 (of 28 total)
  • #535446
    Nigel McBurney 1
      @nigelmcburney1
      why spend cash on new end mills and carbide bits,when a simple home made flycutter with a hss toolbit or broken centre drill ground up to shape costs next to nothing and will produce a better finish as the tool tip rad,cutting clearances,rake etc can be chosen to suit the job by using a bench grinder.The burr is manly caused by blunt tooling.
      Jon Lawes
        @jonlawes51698
        As my mill is smaller I have found flycutting a nerve-wracking experience (vibratory!) and avoid it where possible. I use a carbide insert shell mill instead with good results. It was £25 including R8 fitting and it gets used quite a lot, so I don't begrudge the money.
        Jason, good experiment, thank you. It does look like took sharpness is the critical factor?
        #535501
        AdrianR
          @adrianr18614
          I find I tend to feed too slowly or vary during the cut, what I did was download a metronome app. I set it to tick at twice the speed I need to rotate the feed. Then just follow the ticks top, bottom, top … when turning the feed.
