Endmill size
Endmill size
Home Forums Workshop Tools and Tooling Endmill size
  • #145410
    Brian lightfoot
      @brianlightfoot39268
      Hi there
      Does any body know the biggest four flute endmill I can use in a 16 mm collet please. where would be a good place to buy them i want good quality and a reasonable price.
      Thanks Brian L
      Brian lightfoot
        #145412
        John Stevenson 1
          @johnstevenson1
          Usually 18mm but there are some 20mm ones about.
          Cutwel [ one L ] do them.
          http://www.cutweltools.co.uk/home/milling-cutters/hss-8-cobalt-k2-coated-hsse-cutters
          Most are 18mm but if you look at the multiflute, standard length section they list one at 20mm, these are the cheaper HSS ones.
          Modern carbide cutters tend to have same shank as the cutter because the ER series collets are now the defacto standard and holding say a 7mm cutter with a 7 mm shank is no problem.
          #145463
            MSC have quite a few 20mm ones to choose from with 16mm shank and they have got 40% off today if you use SALE40 in the promo code
            #145465
            John Stevenson 1
              @johnstevenson1
              Don’t forget to apply for a mortgage first
              #145467
                £10.66 with the discount code, hardly mortgage material?? And even without the discount at £17 still £3 cheaper than Cutwel  who want £20.
                J
                Edited By JasonB on 28/02/2014 12:06:59
                #145707
                Thomas Pauley
                  @thomaspauley97563
                  CTC Tools in Hong Kong provide very reasonable priced tooling. I recall their end mill sizes go above 16mm and I have had good results with their products.
                  #145716
                  John Burridge
                    @johnburridge26484
                    Tracy tools do up to an inch end mills with a 5/8" 16mm shank
                    Brian lightfoot
                      Thanks for the help about where to buy from . must be 30 years since I bought cutters but have just bought a myford miller and need a few bits and bobs.
