Posted by not done it yet on 09/11/2017 22:57:47:
Would finishing with a D bit achieve a reasonably flat bottomed hole, after using a milling cutter? Seems the best solution to me.
Maybe!
It rather depends on the interpretation of 'reasonably flat' … and Tim's observation is crucial to this.
To put things into perspective: The theoretical height of the 'bump' produced by an 8mm [4mm radius] cutter would be slightly less than 0.07mm.
Whether this already qualifies as 'reasonably flat' and whether one could improve significantly upon it by a second operation depends on that interpretation, and on the performance of a 'real world' D bit.
Your approach could work … but I think 'production engineering' the job might be more appropriate.
