And yet Harley Davidsons used silicon DOT 5 brake fluid from 1973 until just a few years ago when ABS required a switch to DOT4 conventional fluid. Never ever heard of the silicon fluid giving problems, and there are some serious braking forces and heat generated on their heavier touring models with half a ton of gear added on to them.
Harley specifies no change intervals for the silicon brake fluid, just inspect and top up. Indeed, I have had Harleys go for 10 years and more with the same silicon fluid without problems. But in our wet tropical environment here I have to change the conventional DOT4 fluid in my car and other bikes every two years or less, otherwise it tests over the allowable moisture content and if left will corrode the brake system internals. The hygroscopic fluid seems to suck atmospheric moisture in through the pores in the rubber hoses or around the copper washers, seals etc. Silicon does not.
So all my other bikes without ABS I have converted from DOT 4 to DOT5 silicon and saved a lot of maintenance. Been doing it for years with total success.
US military vehicles all use silicon fluid for this reason too, and I believe NATO vehicles. Except for the ABS fitted ones. Silicon is too viscous to work in an ABS system.
Edited By Hopper on 08/06/2023 01:29:36
