en8 and en8m
en8 and en8m
Home Forums Materials en8 and en8m
  • #256834
    geoff walker 1
      @geoffwalker1
      Hi All
      I am currently making the whittaker firefly and need some en8m for the crankshaft and the bore liner, about 125 long x 30 diameter.
      There is lots of of en8 on ebay but no en8m.
      Is there any difference between them?
      If yes can anyone tell me a supplier of en8m.
      thanks geoff
      geoff walker 1
        @geoffwalker1
        #256835
        Thor 🇳🇴
          @thor
          Geoff,
          Isn't EN8M the free-machining version?
          Thor
          #256839
            Yes its the free cutting one. If you put the modern code into e-bay etc you will get what you are looking for 080A42
            #256843
            geoff walker 1
              @geoffwalker1
              Thanks guys, have emailed wrekin steels to see if they have the size I'm looking for.
              geoff
              #256845
                Sorry wrong code the better machining one is 212A42
                #256850
                Brian H
                  @brianh50089
                  I like EN numbers, you know where you are!
                  #256940
                  geoff walker 1
                    @geoffwalker1
                    Hi All
                    Just had a quotation of £49.30 for a length of 125mm long x 30 mm dia en8dm.
                    I need a drink!
                    #256941
                    John Rudd
                      @johnrudd16576
                      http://www.m-machine-metals.co.uk/metals_cs_diameters.html
                      The above has a limited stock of what you need, best give them a call….
                      #256942
                      Chris Evans 6
                        @chrisevans6
                        The £49.30 is not right, you may get the bar for less than that.
                        Where are you based ? I have a local steel stockholder who I can ask for a cost. I am in the Midlands. Chris.
                        #256944
                        geoff walker 1
                          @geoffwalker1
                          Hi John/Chris
                          I'm sorted now guys, £9.80 including postage from m-machine-metals, thanks John brilliant!!!!
                          geoff w
                          #256965
                          John Rudd
                            @johnrudd16576
                            Posted by geoff walker 1 on 20/09/2016 13:31:59:
                            Hi John/Chris
                            geoff w
                            Geoff,
                            Great result, you can buy me a drink….smiley….
                            I use that particular supplier quite a lot, they are very friendly bunch when you visit their premises, their workshop is something else.!!
                          Home Forums Materials Topics
