Robin, I have no experience of EN42 but use EN45 & 47 regularly for springs and the carbon content in EN42 is sufficient for “normal” hardening, I would suggest heat to 850 C and quench in oil then temper to desired hardness, for knives I would suggest 280 C but you may have to experiment. This would be far too hard for a spring ! You need to temper to 340/350 C for Springs
Look at **LINK** for some info
There a couple of knife makers close to me, one uses files to produce unique products the other uses tool steel, aka gauge plate. Lots of info on the web if you dig around
Edit spelling & typo errors
Edited By JohnF on 25/06/2020 10:03:55
