Anybody know how EN1A mild steel will hold up as a bearing surface? give good thread strength?
From what I have read is that it's used extensively for machining parts because of it's softness and finish you get, if this is the right words to use, but to me it dosent seem to have a lot of uses, no good for stress items or turning shafts, they say it will easily pick up on the mating surface and wear badly and it doesn't have a lot of strength, I dont fully understand what they are saying really, Bronze against steel wears excellent, so soft mild steel against hard steel should be the same?
lee
