Posted by AJW on 16/10/2018 20:43:58:
So do you reckon the
black hot rolled
will machine ok to give good bearing surfaces?
I have made cranks before using built up methods but fancied making one from solid.
Alan
Black is exactly the same stuff as bright, just not been cold worked. As others have said it is much less likely to distort, and machines exactly the same. I can't imagine that the tensile strength of EN1A is an issue for a small steam engine, if it is then EN3 might be a possibility, still fairly easy to machine.
