Emma Victoria – continued
Home Forums Locomotives Emma Victoria – continued
  • #715634
    Bill Dawes
      @billdawes
      Well after 12 years I am at the point of doing a static run test on air. (when I started I thought it would take me about 12 months but allowed 18 as it would be my first ever loco)
      Finally got all the valve gear assembled and working?
      It feels a bit tight turning by hand but I’m hoping a few minutes run will ease that.
      Just waiting for an NPT tap and die to arrive off Tracey tools, I need them to make a connector piece between my steam pipe and compressor.
      Looking forward with a mix of dread and excitement so cross everything for me guys.
      Whatever the outcome I think this will be my first and last loco, I’m 82 now, want to get on with a few smaller projects.
      Bill D.
      duncan webster 1
        @duncanwebster1
        12 years seems quite good. Took me 25 to do my second. Mind you in the meantime I had 3 kids and built 2 extensions. I’m done with extensions, but kids and grandchildren still take up too much time
        #715639
        Bill Dawes
          @billdawes
          Yes know what you mean Duncan, when I started this it was the start of my ‘retirement, still work part time.
          Even so the last 12 years have gone in a flash, my wife and I  have three grandchildren, we love them dearly but try to monitor our time with them so we have time to do our own thing, retirement after all should be retirement from work not life so have been really busy, doing what I sometimes wonder, many weeks seem to consist of doctors, hospital, dentist, opticians, audiologist etc etc, and we are quite fit and healthy! to say nothing of gardening, upkeep of buildings, fencing and other hobbies, oh yes and the odd holiday.
          When we go out for a walk we say how on earth did we cope when we had two young children, full/part time jobs, cricket. football, parties (childrens) McDonalds, parent evenings, fetching to/from school,  catching up with family, phew.
          Bill D.
          #715712
          SteveP
            @stevepye68246
            Bill ,I think you will enjoy building the Stuart 5A engine, bigger parts but less of them.
            I hope your Emma Victoria engine runs well.
            Steve
            #716013
            Bill Dawes
              @billdawes
              Well got there, my heart sank when I first put the air on as I just got a hissing out of the exhaust, I knew it was quite tight so gave it a bit of assistance by hand and off it went.
              Had the valve gear apart several times to find out why it was stiff some time ago but never got it really free.
              Watched a Keith Appleton rebuild on video and he just pushed to loco back and forth on its rails and everyting worked, mine will just skid. Could it be that cylinders have O rings rather than piston rings.
              Not sure whether valve timing is correct though, fully forward how much should the valve reveal/cover the ports?
              Bill D.
              #716051
              Weary
                @weary
                Mr Dawes,
                Your starting point for valve timing check is that in full forward gear, engine at dead-centre, the relevant inlet port should ‘just’ be about to open.
                New loco’s are always a little stiff, that aspect is not too concerning provided there are no obvious ‘knocks’ or clear tight-spots.
                Phil
                #716053
                duncan webster 1
                  @duncanwebster1
                  With walschearts gear I set the valve so that in mid gear it just cracks open on both centres. With the crank on either centre, the valve should not move when going from full forward to full reverse.
                  #717169
                  Bill Dawes
                    @billdawes
                    Took my boiler in for test and (hopefully) certification.
                    I did it with some trepidation as it was my first ever boiler and I did not think the quality was that good particularly as I took it into Western steam who make boilers that look works of art to me.
                    We shall see, to get it passed would be a major milestone as I sweated blood making it, well the silver soldering at least, took a while to realise how much heat you needed (Propane torch)
                    Talking of silver soldering, I’m surprised the ME community hasn’t adopted silver brazing as it’s name rather than soldering, when I talk to people about it I can see that they visualise a plumbers blowlamp and wonder why I make such a song and dance about it.
                    Bill D.
                    #722266
                    Bill Dawes
                      @billdawes
                      Sadly boiler failed test, a couple of weeping rivets.
                      Lesson learned, do a thorough test first yourself, I did do a test but my little hand pump was leaking slightly so could not hold pressure for any length of time, as the boiler did not fail or show any leak I concluded that it was likely to be ok.
                      I have no complaint on test failure, a slight weep may not be an issue in reality during service, after all seeing rivets fizzing on boilers is not uncommon but fully appreciate that when certification is involved a slight leak could be an indication a potential structural problem.
                      Back to the burner then and back to the drawing board for my test set up.
                      One question on this, I used a copper pipe connection from pump to boiler but this of course is a bit inflexible, what sort of flexible tubing is ok for these pressures (180 psi, about 12 Barg.)
                      Bill D.
                      #722317
                      duncan webster 1
                        @duncanwebster1
                        Have you tried a punch and hammer on the rivets? Often slight weeps can be closed up without having to heat. If that won’t cure it I’d be tempted to try Comsol with agreement of your boiler inspector.
                        #722462
                        duncan webster 1
                          @duncanwebster1
                          When chasing weepage you can pump up the boiler with air using a bike pump. I know your not supposed to pressure test with air, but you’ve already done a hydraulic which proved structural integrity at presumably 2*working pressure, so say 40 psi from a bike pump isn’t going to trouble it. For a little boiler like Emma Victoria you can immerse it in a bucket of water and watch for the bubbles.
                          #722465
                          Harry Wilkes
                            @harrywilkes58467
                            Bill
                            I’m surprised your boiler inspector failed your boiler for a ‘couple of weeping rivets’ if they are easily reached you can soft solder them.
                            H
                            #722735
                            Bill Dawes
                              @billdawes
                              Thanks for all the good advice guys.
                              Couple of other questions, well one other really as I have already asked the first one, pipe material for connecting pump
                              As I said I used copper pipe but the drawback I found with that was it doesn’t allow you to turn the boiler easily to examine it all over. In Henry Wood’s book of words a picture showed what looked like a silicon or similar pipe.
                              The other thing is how do you test your pressure gauge is opening at correct pressure, when its steaming or on air.
                              Bill D.
                              #722739
                              Bill Dawes
                                @billdawes
                                Sorry meant safety valve.
                                Bill D.
                                #722776
                                duncan webster 1
                                  @duncanwebster1
                                  Henry uses nylon pneumatic pipe. The working pressures are listed here https://manlon.in/nylontubes.html
                                  Your 160 psi test pressure is about 11 bar, but you shouldn’t go there again. The boiler has been shown to be OK once, as others have said a couple of weeps can be sorted and then retested at say 1.5 times WP.
                                  #722777
                                  duncan webster 1
                                    @duncanwebster1
                                    Double post
                                  Home Forums Locomotives Topics
