A problem I had with the axles/axle boxes was getting it lined up. I carefully bored out the boxes on a jig as suggested in the series but the axle was still a bit out of line between one box and the other.
I put this down to, my inexperience (mainly) and the fact that you are fitting a relatively accurate machined assembly into a relatively inaccurate horn assembly (ie not a machined item, just two bits of angle rivetted on.)
I thought I had fitted these carefully, machining a dummy axle block for the spacing but obviously not good enough.
The frames were accurate as I had these laser profiled (even though I felt this was cheating)
A bit of filing on clearances, making it a bit rattly, solved the problem but I was left with a feeling of a job not well done or am I expecting too much?
Still, slowly pressing on making some of the easy bits (depending what I have the lathe set up for)
Plucking up courage to make a start on the cylinders but gaining confidence as I proceed.
'Looking forward' to making the boiler with some trepidation, my efforts with a GLR vertical boiler were a bit fraught but got there in the so hopefully my silver soldering technique is also better.
Regards and thanks for replies.
Bill D
