Posted by JasonB on 28/12/2022 10:05:36:
As John says if you have the ELS then best to use that as you won't find dies right hand to cut M3 x 1 in any profile let alone left hand as it's a very coarse pitch, standard for M3 is 0.5mm pitch.
Even with an ELS M3 x 1 on M3 stock particularly ACME will be a real challenge as the minor diameter is going to be very small and weak. Should that be trapizoidal rather than ACME form as you are using metric sizes?
Thanks John.
Yep Jason. My error. I've got a heavily (axially) loaded shaft. Trapezoidal will be better as you say, it's metric standard. I thought of this after posting, and was just mulling over the design as you replied. 1mm minor diameter is lunacy.
Biggest issue is going to be grinding the internal thread cutter for a small dia internal thread to match the external thread, then cutting it. A square acme thread was my call there as 90° is easier to grind. Ease of use vs ease of manufacture.
Still finalising design issues on this one.
My biggest concern is that I've got to make this in spare time for delivery in 3 weeks, with the lathe arriving 3 Jan. It'll be tight.
You've all given confidence that I can use the electronic feed to cut this, having not seen the machine yet. Thanks.
Will post results.
Edited By Andrew F in Australia on 28/12/2022 10:37:39
