the drift in the position of the vise corner along the Y axis can be as much as 0.03 mm ….. This is just a 300 lb bench mill so high precision is not expected.
I suspect that a lot of small milling machine owners would be happy with a little over a thou movement ? What are you looking for or expecting ?
According to the parts book for the FB2 (well mine is a Taiwanese clone badged "FV-320T", but the manual appears to be a copy of the Emco original with the Emco badges redacted) the gearbox lay shafts run in plain bushes & it only has a small quantity of oil (can't recall exactly how much I put in, but probably less than half a pint) so it gets warm in use. Anything that gets warm is going to expand.
I am just wondering if the same happens to bigger machines and how people deal with it.
Oh yes – it definately happens to bigger machines ! How it is dealt with depends on how critical the parts are & how deep the companies pockets, but at one end is running "warm-up" cycles at the start of a shift to warm up ballscrews, spindles etc & build up lubrication films before starting to machine parts. That is how tight tolerance parts are machined where I currently work – 20 minutes rapid traversing the machine through it's working envelope with the spindle running, then run 3 parts with no blank in place, then start producing & the critical dimensions come out the same as at the end of the previous shift. Just put a part on the cold machine & they fail inspection.
Then there is actively monitoring temperatures around the machine & applying compensations to the axes to keep the tool stable relative to the part as temperatures change. I have seen a few variations of this method – Oerlikon CNC horizontal milling machines had a temperature sensor on the bed casting which was used to set the temperature of the lubricating oil circulated around the head casting to limit spindle growth, Or a Kearney & Trekker MilwaukeeMatic horizontal machining centre that had an Invar rod attached to the end of the spindle casting that rested on a dial gauge, with a resolver driven by the gauge needle – any movement of the resolver due to spindle casting growth moved the Z axis to keep the tool position constant WRT the job. Some modern CNC controls have inputs for multiple thermistors & compensations are handled through the PLC on the control.
Or there are temperarture-controlled environments. Only saw two of these while at my last employment (though former colleagues worked on two more temperature controlled sites – both defence related) & only one of them was actually functioning – the former DeVleig works at Red Lane, Coventry, which was turned off by the later owner due to high running costs & a printing press manufacturer in Leeds (Crabtree Vickers IIRC) which maintained the whole machine shop at 19C to better than 1 degree C all year round & had airlocks on all the entrances / exits. The machine I worked on there was a DeVlieg 5K120 jig borer with a 10 foot x 10 foot working area – after we had finished doing a CNC conversion on the machine, the owner had the positioning accuracy checked by an independant laser calibration outfit – it was found that the machine could position anywhere within the 10 foot by 10 foot area within a tenth of a thou – required because the bearing bores for the prining press rollers on the side frames only had a 4 tenths positional tolerance. Newsprint running at 30 mph through the press doesn't tolerate mis-aligned shafts !
Nigel B.
