Elliott Progress Drill Press – dismantling.
Home Forums Workshop Tools and Tooling Elliott Progress Drill Press – dismantling.
  • #17456
    Oompa Lumpa
      @oompalumpa34302
      Oompa Lumpa
        @oompalumpa34302
        So, as some of you may have seen, I acquired a lovely Elliott Drill Press. I decided a full strip and rebuild was in order so reduced the thing to it's component parts today and took most of them off to the shot blasters.
        However, I am now a bit stuck. The pinion and pinion shaft are still in there and I really don't want to destroy the casting at this stage. I have no book, manual or instructions. It was pretty straightforward basic engineering with the usual well laid traps – Left hand threads, second grub screws behind the grub screw you just removed but can't immediately see – that sort of thing.
        But now things are at a halt. I gave it "some Wellie" with a lead mallet but there were no signs of movement. Has anyone had one of these apart?
        One thing you will notice – in the top picture – there appears to be a recess for a Halogen type lamp. I will be putting a nice LED lamp in there and using the original motor on/off switch placement as the switch for the light (please note – I will not be using the original switch, it will just appear to be.). I will be fitting a VFD to this.
        graham.
        #158744
        Fatgadgi
          @fatgadgi
          Hi Graham
          What about taking the boss off the other side (probably pinned in place through the boss and shaft) and gently tapping from the other side. I'dbe surprised if wellying was required.
          Looks to me that the pinion will come out of the bore with the bearing – but the other side looks a bit smaller than that.
          Cheers – Will
          #158747
            Graham,
            When I reached a similar point with my little Jones & Shipman drill, I had to heat the casting [with a Hot Air gun] before I could move the pinion shaft [with a Nylon/Lead-Shot hammer].
            … Might be worth a try.
            Oompa Lumpa
              @oompalumpa34302
              Snag is Will – I can't find any sign of a pin. I will scrape some paint off.
              I tried a few blows with a lead hammer Michael, but I am concerned that I was trying to drive it out the "wrong" side. Given I don't know which side it comes out. A drawing would be helpful at this point I think.
              graham.
              #158753
                Posted by Oompa Lumpa on 25/07/2014 22:14:11:
                If all else fails … here is listed a manual for £9.95
                One of many that he offers.
                Edited By Michael Gilligan on 25/07/2014 22:53:34
                #158754
                Bazyle
                  @bazyle
                  Although Elliott is essentially British and this llink **LINK** is mostly american it is the biggest collection of rebuilt drills on the planet. So someone on it might have an idea.
                  #158757
                  Fatgadgi
                    @fatgadgi
                    Hi Graham
                    I have a progress 3 which is geared ( is yours ?) but it looks similar. I can get into the workshop tomorrow morning and check that one for you and see if I can help further.
                    I have had it to bits in the past so it should be obvious once I look at it again.
                    cheers Will
                    #158778
                    Fatgadgi
                      @fatgadgi
                      Hi Graham
                      I've just had a look at mine – yes boss comes off. Its is pinned with a single 1/4" pin through the boss and shaft. Mine is a straight pin through both sides of the boss.
                      The shaft is about 3/4" diameter under the boss and the pin hole is drilled 15mm from the end of the boss. The pin is alighned with one of the holes for the arms. May help find it.
                      looking at mine there is no way that the pinion and shaft will come apart any other way but from tapping out from that side
                      good luck !!! Will
                      #158779
                      Oompa Lumpa
                        @oompalumpa34302
                        Will, thank you for the kind offer that would be very helpful. I am not at work today, we are off to Liverpool, so no danger of me breaking anything meanwhile
                        graham.
                        #158824
                        Oompa Lumpa
                          @oompalumpa34302
                          Will, further to your suggestion – I found the pin. It wasn't easy as it is under a good deal of paint. I have given it a few "taps" – it is in there Will use a bit of heat on Monday.
                          #160541
                          Vic
                            @vic
                            Only just seen this but yes, mines pinned as well. I can't check as it's in storage at the moment but pretty sure it had a domed head like a rivet so if you could grip it, it could be pulled out. I only mention this in case it's a blind hole!
