Hi I have an 00mnimill and the original hand book. For the adjustment of x and y slides the instructions are poor and ust nearly lines long,the x and y slides are adjusted by using tapered gib strips and these are adjusted by push and pul screws at each end of the gibbstrip. As there is no indication which end of the taper is thickest and its not visible,so experiment,slacken one screw a turn or two,and then screw in the screw at the other end if the slide goes tight then the second screw is at the thick end of the gibb ,unscew the second screw a little tighten up the screw at other end and and test the fit,and carry on adusting the tapered gib until the correct clearance is achieved,and there are no tight spots. Te instructions in the handbook are very brief as in the days when this mill was made ie 1960s I expect the majority were in commercial use and most users were apprentice trained, and knew what to to maintain the usual machine tools so istructions were very brief,Very often the instructions were brief, there is a diagram and six lines of instructions on horizontal spindle adjument minimum .0004 ins axial float , no max given and yet it says great care must be taken when adjusting these bearings,Regarding the vertical spindle,there are no instructionsat all for adjusting the bearings and there is only an exploded dwg on pages detailing the parts list.I do not see how the front of the bed is 5 thou higher at the front,which I assume mean the handle end, I can understand the front being lower if the vertical z axis slides were slack and the weight of the knee caused the whole lot to drop. Now the z axis vertical slides do not have tapered gib strips,they are plain and parallel,and adjusted by slackening slightly the three bolts with heads facing front,and pushing the gib sideways towards the v slide,this gib is adjusted by 2 socketgrub screws and lock nuts, Not easy to adjust,I cannot undestand why Elliotts did not use taper gibs on the z axis which are a lot easier to adjust, Elliotts could at times incorporate some cheap nd nasty features, On the sales leaflet I have which came with machine it cost £705 where as a ML7 lathe equipped ready to go was £82 or £120 equipped,so an 00 was relatively epensive.
