Thank you for all of your responses.
Clive/Nigel, i think the weights i will be using are quite safe! (Doubtful i will ever go over 100kg).
Bazyle, its one with dovetails and the knee is motorised, but can also be operated with a handle.
Not Done It Yet, The table is 50 inches, so clamping and placement should be good for my modelling needs!
seems extreme for such a large machine, when i mostly do odds and ends, 7 1/4 gauge railway, and Mk1 Mini restoration work, but i had a small Warco, but that was too small, then this elliott is available, close to home and a good price, so hard to refuse!
