ELECTRONICS
ELECTRONICS
Home Forums Model Engineer & Workshop ELECTRONICS
  • #43982
    Roger Harvey
      @rogerharvey92595
      Hello All,
      Back in Issue No.  147, Mike Crossfield wrote an article describing a low cost rev-counter. This used a disk with 60 slots to generate 60 pulses per revolution of the spindle.
      Is there an electronic device, or a circuit using such a device, that would amplify/multiply the pulses generated by one similar opto switch once per revolution by 60 times. i.e one pulse per revolution increased to 60.
      Wychwar
      Roger Harvey
        @rogerharvey92595
        #43984
        Les Jones 1
          @lesjones1
          Hi Wychwar,
                                  I have put a design for a four digit tachometer that uses one pulse per revolution on the “Yahoo X_Series _Mills forum” in the file section.
          It works by measuring the time  of one or more revolutions and calculating the speed from that. At slow very slow speeds it only times one revolution. (So the display is updated at a reasonable rate.) At higher speeds it times a number of revolutions to average out the speed over about a one second period.
          I hope this will meet your reqirements.
          Les.
          #44245
          David Blunn
            @davidblunn56158
            Hi,
            you could try a Phased Lock Loop (PLL) circuit. Look up (google) some application notes for CD4046 or HC4046 chips. The idea is that you have the Voltage Controlled Oscillator (VCO) running at 60 times the input rate with a divide by 60 device in the feedback path to the phase comparator. The relatively low speeds may make lock-up times too long (the time time it takes to sort itself out) so some experimentation is required.
            Regards, Dave
            #44391
            Peter G. Shaw
              @peterg-shaw75338
              Hi,
              Depending on your requirement, and your speed rating, you could use a cycle computer.
              I have one bought from Halfords which by careful selection of the wheel diameter (1667 I think) means that the kph reading on the display can be taken as rpm. I did find that there were slight restrictions in that as the speed increased, the display at certain points automatically reduced it’s resolution, and that above another speed, it stopped working altogether.
              Nevertheless, from my point of view it allowed be to roughly calibrate my milling machine.
              Peter G. Shaw
