For the labels google water slide decals. You print the artwork onto a special paper. This is then varnished with two coat car top spray varnish from Halfords. Soak in water and the decal will slide off and you gently manoeuvre it into position and gently firm down. Finally spray varnish to seal the lot. It’s very straightforward but practise on scrap first. I tried to see what happened without the spray on the decal, when soaked, it disintegrated to mush. The paper is very cheap compared to what you use!
it gives truly excellent results
dacosta, , I suggested earlier that turning top hat type buttons which can go through drilled holes will work so they won’t pop out. Phil indicated the spring on the led board buttons will be sufficient to return it, but obviously you will need to check the sizes with care. Use plastic if possible, you don’t want any conduction from damp fingers.
Edited By Zan on 21/01/2020 15:02:28
Edited By Zan on 21/01/2020 15:06:57
