Electromagnets (Split From Stuart Dynamo)
Home Forums Beginners questions Electromagnets (Split From Stuart Dynamo)
Viewing 6 posts - 76 through 81 (of 81 total)
  • #767264
      Thanks, Dave
      … Take good care of yourself.
        On Michael Gilligan Said:
        News:
        That nice Mr Ali has a lot of sellers offering Tau 5030 Solenoids, at prices bearing little resemblance to Amazon’s
        But, as we don’t do links to the aforementioned … here’s Amazon:
        https://www.amazon.co.uk/Electromagnet-TAU-0530-TAU-0530B-Solenoid-Keepping/dp/B0CF86CFM7
        Still hoping to keep this topic on the first page of the list 🙂
        I am pleased to report safe delivery of Qty.6 of these solenoids … for a total expenditure of £10.39
        It pays to ‘shop around’
        Edit: __ I bought the 12v ones [blue coil] … They are nicely made and [with no additional load] operate smoothly on 5v
        #768761
        john fletcher 1
          @johnfletcher1
          As source of lamination how about using a Micro wave cooker transformer. As regarding cutting/ milling mains transformer lamination, some years ago I made myself a ‘Growler’ using a large transformer and milled a large VEE in which to place the armature, no problem.
          #768809
          Robert Atkinson 2
            @robertatkinson2
            Microwave oven transformers are not the best choice as a a source of lamination material. This is because the normally have a weld run across the windings. They also tend to use cheap materials. If you have a friendy scrap yard you could try them for an industrial transformer.
            Robert.
            #783116
            rjenkinsgb
              @rjenkinsgb
              A bit late, but just in case its useful to anyone.
              Early telephones used a bundle of iron wires for the transformer core. Florists wire (soft iron) in a bundle should work well as solenoid or transformer cores and be somewhat vintage-authentic.
              Doing a quick search, the plain iron type appears to be sols as “Stub wire” or Stubbing wire, in various gauges.
              Search “florists black iron wire” and look for the stuff in bundles; I’ve just found it down to 24 gauge, though 19 gauge seems commoner.
              #783160
              John Haine
                @johnhaine32865
                I doubt florist’s wire is actually soft iron in the magnetic sense, probably just mild steel these days. What would the advantage be?  Wire “laminated” cores ok for transformers or AC solenoid but not much point for DC, just decrease the form factor and therefore increase reluctance.
