Electrical problem on md65 lathe
Home Forums Introduce Yourself – New members start here! Electrical problem on md65 lathe
  • #39884
    Ian Roberts 1
      @ianroberts1
      Ian Roberts 1
        @ianroberts1
        Hi i am Ian .I am aclock restorer with an md65 hobbymat lathe as well as a watchmakers lathe .My problem is that one relay has burn out on the MD 65 does anyone know where to get a replacement .They are blue and about 1.250 square and about .625 thick. I believe they are double poll double throw . My knowledge of electronics is very limited so any help and advice would be appreciated .
        #238684
          Ian,
          First … Welcome Aboard !!
          Now: You might find this recent thread of interest
          John Rudd
            @johnrudd16576
            Ian,
            Pictures of the offending item might help identify the relay especially if it has any numbers printed on it….
            #238761
            Ian Roberts 1
              @ianroberts1
              Ian Roberts 1.Thank you for your kind replies I have seen the thread and tried it with no luck .The relay has printed on it GBR 40 1-11.240 The coil in the relay is OK but the contacts above have melted. Sorry can't send photo haven't a clue how
              #238765
              Martin W
                @martinw
                Hi Ian
                There is a description of 40 series relays that have a similar numbering system here. It may be a point to start to see if you can identify the correct unit. A good source of components that I use is CPC which come under the Farnell group.
                Hope this helps.
                Martin
                Edit: Do you know why the contacts have melted, is it down to old age or something more serious?
                Edited By Martin W on 15/05/2016 13:14:21
                #238893
                Ian Roberts 1
                  @ianroberts1
                  Hi. Thanks Martin
                  #238894
                  Ian Roberts 1
                    @ianroberts1
                    Hi . Thanks Martin for the information about the relays.I will try and get some from where you suggested.If they work. I shall let anyone else with an md65 know what they are. As to why they melted it is probably old age as I bought it in1990 never had a problem till now. One or two of my bits and pieces are in much the same state. ian
