Electrical Connector Required – Suggestions on Anything Suitable
Home Forums Electronics in the Workshop Electrical Connector Required – Suggestions on Anything Suitable
Viewing 3 posts - 26 through 28 (of 28 total)
  • #717929
    Ian P
      @ianp
      Andy
      You say ‘DC Brushless Motor’ with its controller mounted in the lathe base enclosure. If it is brushless then you need a multipole connector, anything from 3 to 6 (or even more) pins). However your mention of 200V probably means it is a brushed motor so a three pole connector would be suitable.
      I would suggest IEC C13/C14 pair but because they are so common its possible that somehow/someone might inadvertently think they are carrying normal mains voltage and so if wrongly used create damage or danger.
      My suggestion would therefore be to use the much less common IEC C19 and C20 like the ones in these links, lots of other suppliers than RS.
      https://uk.rs-online.com/web/p/iec-connectors/7769144
      https://uk.rs-online.com/web/p/iec-connectors/7769125
      Ian P
      Robert Atkinson 2
        @robertatkinson2
        I agree with Ian that a brushless DC motor would require more than 3 wires if properly installed. It is possible that just 3 wires are used, one per phase, but that would indicate the motor is not grounded. That is a safety (and probably EMC) hazard.
        A link to the motor specification or supplier would be useful. Is it a sewing machine type?
        If this is a connection between a motor drive and a brushless DC motor you should not use a standard C13/14 connector or similar as there is a possibility that someone could plug it directly into the mains. You would also have power on the “earth” conductor, a big no-no. There are connectors intended for this aplication but they are not low cost.
        Robert.
        #718049
        Andy_H
          @andy_h
          Yes sorry my typo – should have been “brushed”
          Thanks for the new suggestion
